Unsolved posts challenge: Week July 31st, 2023
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Check out last week's most popular posts that haven't received an accepted solution yet. If you have a solution for any of these topics, we encourage you to share it. Remember, marking a post as an "Accepted Solution" helps the wider community find answers more quickly. Thank you for your contributions!
Topic
Published Date
I am using Civil 3D 2024, So sorry to say, it is full of bugs
02-Aug-23
ASKED 100 TIMES BUT Plot to Two Different Paper Sizes
02-Aug-23
Importing Survey Points Question
04-Aug-23
AutoCAD 2024 is here! What's your thoughts?
02-Aug-23
Presentation View Corridor Styles
02-Aug-23
Edit Band Style for multiple profiles
01-Aug-23
Create pipe network and label using excel sheet data
01-Aug-23
Online data Imagery
03-Aug-23
Entering bearings
03-Aug-23
Line with arrows in it
02-Aug-23
project located between 2 zones
06-Aug-23
Earthwork (Cut and Fill) on Plan Cross Sections
31-Jul-23
Printing line weight problem
02-Aug-23
Modify Featureline
01-Aug-23
Quick Volume of a surface?
31-Jul-23
Creating a surface with existing and proposed contour data
04-Aug-23
Pipe and structure labeling issue...
01-Aug-23
Section View Projection Style Issue
01-Aug-23
Alignment Relation Report
02-Aug-23
Corridor Transition and custom Subassemblies
04-Aug-23
Object name change different drawing
02-Aug-23
WBLOCK and default units Civil 3D version 2019
31-Jul-23
Add Outer Boundary to Grid Surface that has been Data Clipped
03-Aug-23
Code set style issue
03-Aug-23
Grading Optimization installation issues
03-Aug-23
How to import layout tabs from another drawing without losing original tab order?
02-Aug-23
Labeling Dense Contours of a Complex EG Surface
02-Aug-23
Plan production dwt with more window
03-Aug-23
Referenced surface - contours will not label
03-Aug-23
"Sharing Topography between Revit and Civil 3D" does not function anymore
01-Aug-23
Modify Settings for Create Points at Alignment Geometry
01-Aug-23
Template with Parcel items that won't delete
01-Aug-23
Editing Data in Alignment & Offset alignment
31-Jul-23
How do I turn off swipe selection color?
03-Aug-23
Lines in PDF Export preview
04-Aug-23
"Rest Bends" in Civil 3D Pipe Network
01-Aug-23
Corridor transitions questions
31-Jul-23
Cross Section Plan Sheets - Adjustment Settings
31-Jul-23
Revit shared coordinates - local and grid
31-Jul-23
Alignment Station Report Inaccuracies
03-Aug-23
Custom SubAssembly Behavior
03-Aug-23
Is it me or does "Add crossings to profile view" (still) not work?
03-Aug-23
missing information within viewports
02-Aug-23
Profile Creation for UP and DN Lines
03-Aug-23
Structure in Profile View Not Displaying Correctly
03-Aug-23
Subassembly composer dejo de funcionar
03-Aug-23
Synchronize entire project
03-Aug-23
Adding Ramps to surface/corridor/profile
31-Jul-23
Multiple Corridors in Cross Sections
31-Jul-23
Multiple profile grids in the same drawing
01-Aug-23
Profile view overlapping in plan & profile creation methoda
31-Jul-23
save only 2018 and earlier
01-Aug-23
BATCH VALIDATION DATA CIVIL 3D
02-Aug-23
Corridor Slope Pattern Issue, cannot add Slope Pattern For some Areas.
03-Aug-23
How Can I Create Benching/Step with existing bank side during construction of new bank or formation ...
04-Aug-23
how can i show label in band ground elevation and offset in grade breaks of project elevation band i...
04-Aug-23
Import horizontal points on alignment
05-Aug-23
Inquiry Tool - Elevations Not Showing
02-Aug-23
Profile Band HELP
03-Aug-23
Project Explorer - Point Table Issues
03-Aug-23
Publish Surfaces to Autodesk Docs showing error while importing in Revit
01-Aug-23
test mask override for pipe labels
01-Aug-23
Change annotative scale of xrefed cogo points to be different from the viewport scale
03-Aug-23
Data Shortcut Project Folder Won't Stay Associated
04-Aug-23
Gap in corridor while using conditional cut/fill
05-Aug-23
Is there a way to display a pipe in pipe network that is not intersected by a sample line to section...
04-Aug-23
Link is not working
31-Jul-23
Plot in Two Page Sizes
02-Aug-23
problem of pressurepipe table
02-Aug-23
Station Tracker Not in Front
04-Aug-23
STORMWATER CALCULATIONS
03-Aug-23
Superelevation
04-Aug-23
my cross-section curving inwards at middle of crown
31-Jul-23
Section View Properties - Mass Update Cut and Fill
31-Jul-23
unable to delete a missing subassembly part causing corridor rebuild warnings
06-Aug-23
XREF's & Layer States Manager
04-Aug-23
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
