XREF's & Layer States Manager
Hi all, I tried googling around for this and surprisingly can't find an answer, so I think my workflow may be screwed up here. I work as an OSSF Designer and will sometimes will be doing the design for our own Civil jobs where I have created the layout, and other times working off of another Engineers work. In the past, I've always copied and pasted linework from other files into my file, which I'm not a fan of, and using the layout file as my only file and not xreferencing is a pain because that file will a lot of the time not have my settings/styles/etc. and importing all those settings is so tedious, and sometimes the file wasn't created from Autocad C3D but instead with base autocad, causing other issues. I'm instead trying to follow a more appropriate workflow. What I'm trying to do is use my design file as the "main project file", so I would be xreferencing the layout, title block, and data referencing the surface. This is going well so far, but the HUGE problem I'm having is the layer states manager. If it is our own layout file, then my layer state is already set up, but it wont work because the layers are no longer A-ROAD, but is now XREF_LAYOUT|A_ROAD, and all of the sudden my layer states really aren't working anymore. It works for my layers on my design file (eg septic layers), but any layers that are from an XREF need to be manually adjusted, every time. Now, I understand why it's not working, but I'm trying to figure out HOW to get it to work. Does anyone know a way to do this properly (assuming the xref'd layout file originates from my template, where all layers (that don't have XREF_LAYOUT| attached to them) are known and already accounted for in my layer state manager), or am I approaching this the wrong way?
Sorry for the lengthy post, was tough to summarize!
