Add Outer Boundary to Grid Surface that has been Data Clipped
OliverE
OliverE
Does anyone know whether you can add a non-destructive outer boundary to a grid surface. In the attached dwg I have created a grid surface, added a data clip boundary, and added the attached 2m grid DEM file. I know data clip boundaries are destructive, so I have offset the data clip boundary by 4m from what I'd like to use as my Outer boundary. When I go to add the Outer boundary, the non-destructive tick box is greyed out and I get an error.
I'm assuming this is because C3D won't retriangulate a grid surface along the outer boundary because it would no long be considered a grid once points are added in locations that don't align with the grid layout?
Windows 10
C3D 2021
ecfernandez
Hi @OliverE, wouldn't it be possible to use just the outer boundary? I opened your file and checked it, but it was difficult to understand why both the data clip and the outer boundary are necessary since they perform a very similar action on your surface. Could you please explain this a little bit more?
Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
OliverE
Hi @ecfernandez  thanks for responding. The data clip is there because the full site is much larger than stage 1 and the DEM file, which covers the entire site, will be updated throughout the course of the development. Therefore, the data clip speeds up the processing time for rebuilding the surface when the DEM file is replaced by updated drone data. However, a data clip boundary is destructive, so I lose some triangulation along the defined boundary. This creates holes in the greater surface when two adjacent stage surfaces are used beside each other.
I know I can clip the DEM using software such as QGIS, but want to eliminate this step by using the C3D features that are designed to achieve this. I also don't want to rely on others knowing they need to complete the additional QGIS step if updated data becomes available. Much simpler if the only step is to replace the DEM file in the master surface.
Furthermore, I know I can create cropped surfaces from the full site surface, but this too doesn't work on grid surfaces. Assuming it is for the same reason that outer boundaries aren't permitted on grid surfaces due to the retriangulation along the boundary violating the grid spacing properties. Using a TIN master surface and creating cropped surfaces from that results in drawing files that are double that of the grid surface which essentially defeats the purpose of cropping.
Maybe I've missed something in my understanding of the above. If anyone could shed some light on the situation that would be great. Alternatively, I will create a suggestion for C3D to include cropping and non-destructive boundaries on grid surfaces and post the link later.
