Corridor transitions questions
Hi forum, i am currently doing some evaluation for a possible switch to civil 3d in the future, so i have some questions regarding corridor transitions:
Is it possible to change transition stations with grips instead of pick station?
Is it possible to link two lines in the transitions vista? For example start station = use end station of previous line, start parameter = use end parameter of previous line
is it possible to link the start station to a coordinate? So the station would be updated trough a point relative to the alignment if the alignment is modified.
are the stationings related to the alignment objects? How are transition stations updated if the alignment is slighty modified?
Thank you for the help!!!
