Inquiry Tool - Elevations Not Showing
rilesblomenkamp
rilesblomenkamp
I have used the inquiry tool for elevations every day I have used Civil 3D (2017). My issue is that I received a drawing with a surface already created. While using the inquiry tool, the only data that I can get to show is the x & y coordinates. I usually utilize the station, offset, and surface elevation data. I have tried auditing, restarting, and verifying that I am taking points within the surface boundary. If I open up another drawing, I am able to view the data
needed. Are there some properties disabled from the surface? If so, how does one enable them? Screenshot 2023-08-02 103457.jpgScreenshot 2023-08-02 103613.jpg
acad_ahossain
Hi @rilesblomenkamp,
Can you make the surface triangle with border and check the inquiry location with this style?
Mithasha
Community Visitor
Community Visitor
I am having the same issue with my Civil3D 2025 version. Has a solution been found for this?
