Civil 3D Forum
Lines in PDF Export preview
1 REPLY 1
xracla00
156 Views, 1 Reply
i have a problem with PDF export. When use preview of the PDF my lines are all made out of dots. After really i zoom out it looks fine. Is there any way to fix it?
Labels (1)
1 REPLY 1
lim.wendy
in reply to: xracla00
Hi Jaroslav,
Welcome to the Civil 3D forum. Thank you for submitting your question in our discussion forums.
Could you kindly provide additional information? For instance:
  1. The specific version of Civil 3D you are using.
  2. The operating system on your PC.
  3. A screenshot of the Plot Dialog Box, if possible.
  4. Have you encountered this problem across all files/drawings? Is it also happening on other computers?
 Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Rail Community
