Alignment Relation Report
ritesh_trivedi885J6
Message 1 of 10
ritesh_trivedi885J6
I have a doubt in alignment relation report. While generation report all the columns are empty.
There is no Data in the report.
When i deselect profile....it is generating horizontal data (shown in below pictures)
In this case it is generating only horizontal data.
Please provide a solution as to how can i generate the entire report with all the data
Replies (9)
Message 2 of 10
ecfernandez
Hi @ritesh_trivedi885J6. I think the problem could be that both alignments should have a profile, either designed or sampled from the terrain. In this way, the report shows the complete information it was meant to give. (see an example, in this example, the offset alignment "offset" has no designed profile but just a terrain profile)
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Message 3 of 10
ritesh_trivedi885J6
Thanks for the reply @ecfernandez . Profile for offset alignments are created on the basis of parent alignment offset (like shown in the below picture).
Is this method of creating design profile for offset alignments is ok? because its not working at time of report generation. If my method is not correct, Please suggest a solution.
Message 4 of 10
ecfernandez
I haven't tried what you mentioned. I would have to do it to be sure it works with these kinds of profiles. However, what I tried to make you realize was that, from the image you posted, I could see you didn't select any profiles, and that's why the report is not showing that information.
Select the profiles, try again, and let us know if it worked.
Best regards!
Camilo Fernández
LinkedIn
Message 5 of 10
ritesh_trivedi885J6
Thanks for the reply. I tried with selecting profile as well......its generating blank report. However, when i don't select the profiles, it will generate the data related to horizontal alignment but after selecting profile, it won't generate any data at all.
This is the main issue. Please try to find a solution to it.
Message 6 of 10
ecfernandez
Can you upload your DWG file to try to get the report on my computer?
Best regards!
Camilo Fernández
LinkedIn
Message 7 of 10
ritesh_trivedi885J6
Yes, I am working on a practice alignment. Uploading the same here.
Best Regards!
Message 8 of 10
udo.huebner
Autodesk Support
Autodesk Support
Your offset profile starts at station 0+170. If your report also starts here, you will get the desired results.
Message 9 of 10
ritesh_trivedi885J6
okk.......Got it.
Thank you so much for the help @udo.huebner @ecfernandez
Message 10 of 10
ecfernandez
I came late over here. Good to know that @udo.huebner could check your file and help you @ritesh_trivedi885J6. Best regards to you guys!
Camilo Fernández
LinkedIn
