Create pipe network and label using excel sheet data
Bin2009
Bin2009
I have a excel spreadsheet, which have pipe coordinates and elevation, pipe materials, see attached file test.xlsx.
I want to use those data generate pipe profile and labels as show in the attached image profile.PNG.
Is anyway I can import the data to civil 3d, and how to setup the pipe label?
Thank you in advance!
Bin
lim.wendy
Hi Bin Feng,
Thank you for submitting your question in our discussion forums. You should be able to accomplish that using the Map 3D functionality. Here are some helpful links that might assist you:
Importing GIS Data Into Pipe Networks with Civil 3D 2012
how to create pipe network using excel sheet data
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Joe-Bouza
Hi Wendy
I have done this with success. Do you know if Excel can be saved to shp or some place in-between to be able to data connect?
Joe Bouza
Bin2009
Hello Joe,
I don't know how to save excel to shp file, I try to look at AcrMap how to do it now, thanks
Bin
lim.wendy
Hi Joe,
Since Civil 3D includes Map3D functionality, you can link detailed information from Excel to Map 3D graphical objects. See this
Wendy Lim
Rails Summit
Joe-Bouza
Thanks 🙂
Joe Bouza
