Code set style issue
f_paccapelo
f_paccapelo
Hi
I'm trying to insert dimension label to a corridor's type section, but somehow it can't read the vertical dimension.
Here's an image of the problem
I would like to view both dimensions: vertical and horizontal, but the first one it's always 0.
How can i solve this?
Here's the codes of the used subassembly
Thank you very much for the help
Mike.M.Carlson
It is zero because the distance in that Code Set Label option is X distance only. Vertical lines will have X = 0. Did you check your component editor to see if there is a vertical distance option? Custom SA looks good BTW 🙂
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
bonteng88
Use/Make this expression in this sample "High" , for your L10 and L11 Dimension Style
