Hi everybody
how can I show the label in band ground elevation and offset in grade breaks of project elevation in Section View?
thanks
If you are familiar with how to modify the Styles for the band labels, in the Text Component Editor you need to add "Profile 1 Elevation Minus Profile 2 Elevation" to get the difference between the two surfaces.
unfortunately, there are a lot of experts in the group but my problem wasn't solved!
