Modify Featureline
Modify Featureline
adamTPTQA
Message 1 of 8
Modify Featureline
adamTPTQA
When editing featurelines, how do I stop from being able to select featurelines that are turned off? I only want to be able to select featurelines that are turned on for modification.
Replies (7)
Message 2 of 8
brian.strandberg
I'm not 100% positive I understand the question.  If you have a feature line (or any other object) on a layer that is off, it is still selectable.  If you freeze the layer you won't be able to select it.
I have long wished that Autocad had an 'unhittable' property where I could see it but not select it.  But it isn't there yet.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 8
cwitzel5NL5H
You may also want to look at Sites.  They allow you to put feature lines in different "containers" that do not interact.  While editing you can select which site you want to edit.
Conan Witzel
Herrera Inc
Message 4 of 8
adamTPTQA
Correct. The layer is off but when I try to modify a different featureline on a different layer, that is on, using the "Quick Elevation Edit" tool, the line that is off is editable. I will try to post a screen shot.
Message 5 of 8
adamTPTQA
Screen shot.
Message 6 of 8
MMcCall402
Try locking the layer of the objects you don't want edited.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 7 of 8
adamTPTQA
Thanks Mark. Good suggestion, and the off featurelines are not able to be edited, which is great, but the grip for them still shows up and makes the desired line more difficult to select to edit. The goal is to be able to make the edit without having to navigate unwanted grips.
Message 8 of 8
Joe-Bouza
I think what you want is to set the site to edit. See the command line
Joe Bouza
