"Sharing Topography between Revit and Civil 3D" does not function anymore
peter.petschek
peter.petschek
Civil 3D 2023, Revit 2023, Autodesk Desktop Connector 16.3 are installed, the ACC account has full permissions, ACC project exists.
"Sharing Topography between Revit and Civil 3D" as described in the HELP is applied. I used it already many times.
Now in Revit I always receive the error message "The topography data does not contain usable surfaces" (see attachment).
It worked fine till last month, I still have the .shared.dwg. The workflow works with the old data.
Now it does not work anylonger, I tried different ACC's, old Desktop Connectors, etc.
I have no  more ideas, what to do ... .
tcorey
Are you using the Shared Reference Point utility?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
tcorey
Hi @peter.petschek
Tim Corey
Redding, CA
peter.petschek
Yes!
Todd_Rogers
@dsimeone is looking into this for us. Thanks Dave!
Todd Rogers
Civil Administration at Walter P Moore
peter.petschek
In order to share Topo between C3D 24 and Revit 24 I use ifc 4.3 now
