Gap in corridor while using conditional cut/fill
bhuju82
bhuju82
Hello Everyone.
Here I am trying to create road of different width using the cut and fill height at center point.
There are three assemblies, two with conditional fill/cut and one with out.
The one without conditional fill/cut work well in corridor but the twos with conditional fill/cut causes gaps in corridor.
Please someone explain me this and how to solve this.
m_kingdon
A photo or uploading the file is needed to understand the problem.
Mike Kingdon
Civil 3D Zealot
bhuju82
Here Alignment and profile doesnot make much sense but it is not an concern here due client request.
Here I want use use "assemly-I want to use" assembly for corridor but it causes gap in corridor ,
Please some one help me through this.
bhuju82
Is there issues with my conditional cut/fill assembly?
nkiakas
hi @bhuju82
Did you create your subassembly in SAC?
If yes can you share the pkt file? (rename it to zip before sending)
bhuju82
No I did not made it ni SAC but in civil 3d modelspace.
