Presentation View Corridor Styles
mmuileboom
mmuileboom
I have made a corridor and with the code set styles I made the view as shown below. On the left side my corridor shows the sandfoundation from a lower link instead of the concrete from de top link. On de right side everything is working fine. (the sand shown on the right side of the concrete is intended to be so). Is there some kind of 'attribute order' or 'bring to front or above button' to make sure that the style of the top link is always shown above?
Joe-Bouza
Im not sure you fully explained ? What is not right in the image?
I doubt you can show the top and bottom same time unless you can apply transparency to the code set… which I think you can
Joe Bouza
mmuileboom
Hi Joseph,
Thanks for your response!
The problem in this case is the left side of the corridor. (blue arrow) Here you can see the yellow color of the sand foundation of the road. I'd like to see the concrete color of the road itself, just like the right side. In the assembly (screenshot below) I used the same link codes on both sides. That's why I don't understand why the left side shows the sand and the right side the concrete. I just want "the most above link" to be shown.
Joe-Bouza
Not sure.
you can try adding generic links to ride the top and customize the code to use ( something different )
Joe Bouza
mmuileboom
Thanks again for your response. For now I can indeed work around the problem by adjusting the link codes or change the code set styles. Still, it's a bit strange that Civil 3D doesn't show the top link code in the assembly at the top of the corridor by default. It all seems a bit random now. Would be nice if this was adjustable. Maybe something for the next version.
Mark
