[Circularize/Regularize Tool] A versatile, competitive and well-integrated solution to rearrange selections into Circles/N-sided + other handy options like Maya's Circularize/Modo's Radial Align tool
Ten years ago, this kind of option would have been considered an optional, of marginal use or a fancy tool that is better tackled by scripts. However, it pretty became basic nowadays and most of the software out there has more than decent built-in solutions for these kinds of tasks. One cannot grasp the utility and versatility of such tools until it starts to use them and realizes how much has missed it all this time. This is useful when, for example, when you want to cut out perfect circles on any surface, when you want to build structures that jut out of existing shapes etc. One can use circularize with other modeling operations to model shapes quickly. For video examples for traditional polygon modeling, it's enough to hint at older or more recent Arrimus 3D tutorials (link). For Modo here is a quick video from Pixel Fondue (link)
Now, that 3ds Max team has come up with some fast and versatile solutions for direct modeling like the Interactive Smart Extrude functionality and the much quicker Working Pivot alignment, a competitive solution to rearrange selections into circular arrays (and N-sided shapes) will only exponentially advance the possibilities of the new workflows introduced with these tools. Lesser need for Boolean operations, lesser need of using cut operations and cleaning work (with traditional Quad modeling this is even more critical), lesser need of creating extra primitives within smart extrude etc. The quick designs made up with Smart Extrude will look less blocky and more interesting much faster. All these tools combined along with a future updated Multi Cut tool (that “slices and dices”) will pretty much make 3ds Max the king of direct, straightforward polygon modeling.
There are at least 3 methods to (kind of) rearrange selections into circles in 3ds Max natively. For example, one can use the Spherify Modifier, which is nice because you can also morph, or one can use the Geopoly in the Ribbon Tools. And ofc there is the old Loop Tools Circle Command (from Ribbon). But none of these is convenient enough to use and each of them fails in many cases. Therefore, they are not good alternatives to scripts that already do this conveniently and work in more cases like RapidTools fastEdgeLoopRegularizer (link). Loop Tools Circle Command is buggy, slow and doesn’t work in many cases, at least not without workarounds. For ex, as some of you have already noticed, Loop Tools Circle Command can only circle edges where there's an inset around them.
3ds Max doesn’t need 3 unsatisfying ways of doing the same thing, it only needs a fast, versatile, up-to-date, refined, competitive and well-integrated tool. Furthermore, built in solutions for tools that pretty became basic nowadays are always common sense. Autodesk should go beyond fixing and updated it by taking the lead at least on this low-level polygon modeling functionalities and make it super versatile.
And ofc, there is The Competition. Maya 2018 (if one can considered it as competition) also received an awesome Circularize Components function (link) with bunch of neat options. It’s ridiculous how polished and versatile is that tool in Maya, a software that isn’t, by any means, focused on modeling. It seems they have thought of everything. Cinema 4D  which used to have a limited amount of modeling tools came with a slew of improvements with S26, one of them being a quite competitive Fit Circle tool with lot of control after the software used to relied on scripts to do that (link). Blender has its default addon LoopTools with a Circle operator (link) that works surprisingly well. Recently the team decided to slowly implement important Loop Tools operators in core Blender directly, and rewrite them in C++ and Circle would be the first one link. And last but not least, there is the Modo’s Radial Align tool (link) introduced by the milestone 901 update was inspired by a largely used popular script and this is showing because the result is just brilliant. Apart from the obvious circle arrangements, this tool also supports N-sided shapes defined by user which results in triangles, pentagons, hexagons etc. dispositions. It also has a unique option (Rotate) to reconnect the proper edges when the results get twisted (check this video around 0:30 link).
This new tool should reside in the Command Panel not in the archaic Ribbon Submenus (as part of the badly integrated Graphite Modeling tools) and by default accessible from Quad Menu (or a future updated modern context menu but that’s another story). Consistent Hotkeys are also needed. Its Options should be added to a 3ds Max Caddy Controls.
The most obvious and common-sense place where Autodesk should get the concept and maybe the tech for a new tool in this area is the Circularize Components of Maya. But, it should definitely get the N-sided mode and Rotate reconnect features of Modo or the Influence and Radius from Blender, as well as a couple ones I came up with inspired by other tools (like Randomize, Semicircle mode etc.). When comes to the name of the tool, considering all of these, it can be diffiicult to properly choose one to accurate depic the function of this tool. In essence it rearranges your selections in regular or N-gons or put it differently in radial patterns. Therefore, Radial Regularizer or Radial Align would fit the best, but, for the sake of consistency between Autodesk software, Circularize should also do the work.
MODE
Controls the alignment procedure:
  • Circle - adjusts the selected positions to align along a circle specified by the Radius value and the calculated center position.
  • N-Sided - aligns positions along a polygon specified by the Side and Rotate values. If the number of selected positions is less than the number of sides, it interpolates the remaining points between the corner points of the polygon.
  • Semicircle - aligns positions along a semicircle
While rearranging your selections into perfect circles would be the most used mode, triangles are always nice-to-have details in scifi designs and having the ability to define a shape with the number of sides of your choice ofers way more flexibility. This will alleviate the need to use the cut tools and reduce the post cleaning work. In Architecture and furniture design arches or semicircles are even more common shapes so I think this mode can be tackled inside the same tool even if this doesn’t enter in the same field of radial dispositions.
TYPES OF SUBOBJECTS
The tool should support all subobjects (vertices, edges, polygons). For it to work:
  • For vertices: You must select at least three vertices. The number of selected vertices will determine the shape of the circularized area (i.e., three creates a triangle, four creates a square, five creates a pentagon, etc.).
  • For edges: Circularize is performed on each closed edge loop.
  • For polygons: Circularize is performed on each set of polygons that share at least one common edge.
For the other N-sided mode, in Modo, if the number of selected positions is less than the number of sides, the program interpolates the remaining points between the corner points of the polygon.
TYPES OF SELECTIONS
Like it's Maya countepart at least, (and to a certain degree, by what I've been testing so far, in Blender as well) it should work on selections whether being previously insetted or not (unlike the LoopTools>Circle) on single or multiple groups of selections (identical or different in count and size), on multiple groups being planar or not, if they consist in multiple cross-section loops, simultaneously on both internal and external border selections (even if not aligned or different shape or count) etc.
TYPES OF SURFACES
It should work on Planar or Non Planar surfaces, on Corners areas, with Cross-Section selections, Surfaces with Curvature etc. All this use cases are illustrated below and you can also watch this YouTube video of a comprehensive review of Maya 2018 from 14:32 to 17:48 (link)
OPTIONS
The Tool should provide at least these options found in Maya, Modo and Blender:
  • Radial Offset: Adjusts the initial radius of the circle. If interior components are also selected, then they will scale along with the offset as well.
  • Twist: Determines how much rotation is applied to the components around the center of the circle.
  • Evenly Distribute: Specifies whether or not circularized vertices are evenly distributed along the circle's circumference.
  • Relax Interior: Adjusts the spacing between components so that they stay within the circle while remaining evenly spaced. Lower values will enforce the components' original spacing.
  • Rotate Reconnect: Changes which edges get connected if the initial result geometry gets twisted (check this video around 0:30 link)
  • Normal Offset: Adjust Normal Offset to move the circularized components (and interior component, if selected) along the average normal.
  • Influence: The force of the tool. Zero percent influence means no changes will be made to the mesh. 100% influence means that the input will be fully transformed into a circle.
  • Radius: This overrides the radius calculated by the tool. Useful if you wish to create several circles of the same size, or if you need more precision.
  • Normal Orientation: Determines which set of components normals (face or edge loops) are averaged to orient the circle.
  • Random Radial/Normal Offset: Having a Random Range Value for at least Radial and Normal Offset is a quick and handy way to get instant diversity within your groups of selections. Ofc with radial offset this is only needed when the groups themselves have the same count or size because otherwise they already have differences after being circularized.
  • Add Divisions: Adds additional vertices to the current selection, which results in smoother circles.
  • Supporting Edges: Add supporting edges to the added divisions to avoid n-gons; choose whether to apply them to the inside, outside or both sides of the circle.
  • Alignment: Use Alignment to define whether or not the circle conforms to the original object. With Automatic the circularized components are rotated based on the average normal direction of selected components. With Surface they conform to the surface of the original shape using individual vertex normals or the normal average.
____________________________________________________________________________________________
MY OTHER IDEAS
MODELING
UI AND VIEWPORT
OTHERS
23 Comments
Br0ken1334
Maya 2018 received an awesome Circularize tool with bunch of options. Maybe it's time to update poor Circle tool in 3ds Max too?
There is cool scripts like rapidtools fastEdgeLoopReguralizer, but I hope that built-in solution will be more appropriate.
Tags (5)
yeah its insane how polished and versatile is that tool in Maya. It seems they have thought of everything.
Ehsan.Sarahian
After about 3 years or more without any major changes in polygon modeling, Max need some updates in this aection.
electrotoast_old
so Max who is supposed to be the king of subd polygon doesnt have decent circularize tool yet ? Look at some free scripts out there  and see how smooth they work like the Fast edge loop regularizer
cmon lest  do it for Max 2021. Its embarrassing.
there are some good alternatives in max. For example one can use the spherify modifier, which is nice because you can also morph. or one can use the geopoly in the riboon tools. ore one can use loop tools -> circle (from ribbon). so there are at least 3 methods to do it in max natively. what are you missing?
mgmcgill
@Anonymous , I don't see what you are talking about with those alternatives being "good".  Can you really model using one of the built-in tools you mention the way that Arrimus3D shows here using a script?
max only needs an up to date refined and competitive circularize tool, not 3 "WAYS". Built in solutions for a tool that pretty became basic nowadays are always common sense. Also this updated tool should be added in the command panel for edit poly not on the archaic ribbon submenus.
I've made a robust, detailed and well-illustrated idea on a similar tool implementation (so that others dont have to...) so might worth voting on this as well.
[Circularize Tool] A versatile, competitive and well-integrated solution to rearrange selections int...
Great post!
Very detailed and accurate.
Hope Autodesk takes notice.
hwoRX6FJ
Very necessary!
lupu_mihail
Cool idea to have something like this as default in max. I use a mxs for this.
check this GIF:
 https://imgur.com/vr2qIpo
Is that your own script? Does it works better in certain cases than the Maya one?
@lupu_mihail If that's RappidTools regularizer, you're missing many of the features that @Kranos_Orphydian listed from Maya's circularize tool.
lupu_mihail
No, is not the RappidTools mxs. It is a little bit more than that.  It is a personal mxs but it will be nice that if dev team will implement something like maya's circularize tool. Vote, vote , vote this! 🙂
I see the Smart Extrude it's getting more and more refined and that Working pivot snap and alignment it's on beta and shows great potential together with the former. This will further direct straightforward modeling even more. Now a versatile Multi cut tool and a Circularize command similar to Mayas will pretty much seal the deal in this department. Let's go Autodesk!
mgmcgill
Yes. This is a great Nuts and Bolts suggestion that would bring great quality of life to Max modeling. It already has some serious built-in advantages over Maya with the modifier stack but there are various "little" aspects like this that could be adopted to overcome Maya's few advantages in modeling. This one is a game-changer in Maya and would be in Max too. (And make it better than the rapidTools Loop Regularizer with these suggestions here).
@mgmcgill @lupu_mihail @Anonymous @hwoRX6FJ  Thanks to Autodesk, giving the ability to edit your original Idea post on this board, I greatly updated this idea with better presentation and content. I guess I'm open for other suggestions to include here.
