[UI] [Modeling] [Command Pannel] Unify ribbon\graphite modeling tools with Editable\Edit poly tools inside an upgraded and redesigned Command Panel
Unify Modeling tools under the same roof, they are scattered all over the place. Integrate the remaining Ribbon unique special functionalities into Edit/Editable Poly in an upgraded Command Panel. Why is it split? Basically, it is based on Edit Poly, so why confusing new users that there are many more tools than there are.
Also, all these tools should be all added and unified inside their own menu on the menu bar.
A similar thing was done with the Mayas new UV toolkit editor. Packed with features but so tidy organized, with nice iconography and submenus
Maya UV tookit.jpg Autodesk_Maya_UV_Editor_Menu_Bar.pngAutodesk_Maya_UV_Editor_Context_Menus.png
6 Comments
joeaf9321
I gave a vote, but the Ribbon is designed like a over-all super toolbar where you can setup all of your commands as you like, not only for modeling. But yes, they have to work on integrate the tools of the ribbon to Edit/Editable Poly, these modifiers have a lot of functions and parameters that we use in modeling but it's kinf of difficult to use sometimes.
they should also be collected and added in some Menu or menus on the menu bar. Not that more advanced users would use the menus but this is kinda standard. If the unification of ribbons extra functionalities into the edit poly and some others modifiers, I doubt creating the menus would be that hard.
If the unification of ribbons extra functionalities into the edit poly and some others modifiers would be a difficult task , I doubt creating the menus would be that hard.
impacman
Absolutely!
Ribbon should be just quick favourites and nothing more!
Definitely needs to be unified, i don't know if edit poly should include all the extra commands in ribbon because it is already a hassle dragging up/down the menu in edit poly. Maybe add some collapsed menus in edit poly as Vray menus with "basic or advanced" button to show extra functionalities.
* moved to original post
