useful addins for Robot (API)
Stephane.kapetanovic
Mentor Mentor
Message 1 of 1
A copy of a popular discussion thread from 2012.
API Tutorial
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-tutorial/td-p/13253385
Addin for displaying properties on selected only objects
http://forums.autodesk.com/t5/robot-structural-analysis/afficher-les-attributs-pour-les-objets-selec...
Addin for Selecting Objects By Orientation
http://forums.autodesk.com/t5/robot-structural-analysis/api-selecting-objects-by-orientation/td-p/53...
Rounding up / down coordinates addin
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/td-p/3430533/pag...
Ordinary round coordinates addin
https://forums.autodesk.com/t5/robot-structural-analysis-forum/ordinary-round-coordinates-addin/td-p...
Macros for contour points modification and rounding
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/panel-co-ordinates/td-p/3168358/highlight/tr...
http://forums.autodesk.com/t5/robot-structural-analysis/panel-contour-points-modification-api/m-p/58...
Macro for correcting nodes position by defining the path
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-correcting-nodes-position-by-d...
Macro for rounding nodal coordinates
http://forums.autodesk.com/t5/robot-structural-analysis/api-how-to-modify-the-ubication-of-nodes/m-p...
Models Comparison
http://forums.autodesk.com/t5/robot-structural-analysis/api-models-comparison-1-0/m-p/5651449
Macro for weeding \ removing intermediate points of panels
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Addin-Weeding-remove-intermediate-points-for...
Addin for curtain walls cutting
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-wallcutter/m-p/5588636
Addin for intersection panels with each other
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-for-intersection-panels-with-each-...
macro for creating panel profiles from bars
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-creating-panel-profiles-from-b...
Addin for intersection/extension bars to plane
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-for-intersection-extension-bars-to...
Merging bars addin
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-merging-bars/m-p/132033...
Merging panels addin
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-merging-panels/td-p/842...
Addin for changing bar length by moving existing nodes
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-for-changing-bar-length-by-moving-...
addin for bar offsetting = copying bars in LCS directions of bars
http://forums.autodesk.com/t5/robot-structural-analysis/api-bar-offsetting-copying-bars-in-lcs-direc...
Addin for changing one bar node onto different one
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-changing-one-bar-node-o...
Addin checking flatness of panels, contours, claddings
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-checking-flatness-of-panels-contou...
objects geometry to triangles converter
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-objects-geometry-to-triangles-converter...
macro for converting panels to claddings
https://forums.autodesk.com/t5/robot-structural-analysis-forum/macro-for-converting-panels-to-claddi...
macro for creating 1  panel = 1 FE
http://forums.autodesk.com/t5/robot-structural-analysis/get-local-axis-of-finite-elements-via-api/m-...
Bars to Lines Converter addin
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Bars-to-Lines-Converter-addin/td-p/49225...
Lines to bars converter addin
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-lines-to-bars-converter-addin/td-...
Macro for Stories levels correction
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-VBA-Excel-for-stories-levels-modificatio...
Macro for geting and creating cartesian set of structural axes
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-geting-and-creating-cartesian-...
Macro for highlighting nodes with instabilities
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-highlighting-nodes-with-instab...
Addin and macro for detecting short calculation elements
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-short-calculation-elements-det...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-detecting-short-calculation-el...
addin for applying brackets on both sides of bars
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-applying-brackets-on-both-side...
macro for adding section in rsection dialog box
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-adding-section-in-rsection-dia...
macro for Pile foundation generation
http://forums.autodesk.com/t5/robot-structural-analysis/api-pile-foundation-auto-generation-in-robot...
Macro: Creation of quasi T & L beams
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-creation-of-quasi-t-amp-l-beams/td...
addin for creating closest nodes between bars
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-creating-clossest-nodes-betwe...
Contourize is an add-on for Autodesk Robot that converts panel objects generated by the Extrude tool into normal contour panels.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/convert-panel-objects-generated-by-th...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-add-on-Contourize-API/m-p/3358865/high...
Addin Bars Under The Curtain Walls
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Bars-Under-The-Curtain-Walls/td-p/460737...
bars to rigid links converter
https://forums.autodesk.com/t5/robot-structural-analysis-forum/bars-to-rigid-links-converter-add-in/...
Spider - the multi-tool with rigid links
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-spider-the-multi-tool-with-rigid-l...
Diaphragmer - work with diaphragms in another way
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-diaphragmer-work-with-diaphragms-...
Macro for replacing compatibilities existing in model for new one
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Macro-for-replacing-compatibilities-exis...
Addin: Walls To Loads
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-Walls-To-Loads/td-p/4684075
Macro for creating superbars \ supermembers in Excel table
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Macro-for-creating-superbars-supermember...
different manual combination table,
https://forums.autodesk.com/t5/robot-structural-analysis-forum/different-manual-combination-table/td...
macro for adjusting combination names
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-adjusting-semi-automatic...
macro with inceremental buckling combination
https://forums.autodesk.com/t5/robot-structural-analysis-forum/macro-with-incremental-buckling-combi...
Converting nodal elastic support generated from planar support onto nodal support
https://forums.autodesk.com/t5/robot-structural-analysis-forum/converting-nodal-elastic-support-gene...
Addin for changing bar forces with node generated load onto no node load.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Addin-for-changing-bar-forces-with-node-...
Addin for coping loads for Load Cases
https://forums.autodesk.com/t5/robot-structural-analysis-forum/addin-for-coping-loads-for-load-cases...
Macro - linear load converter to line load
https://forums.autodesk.com/t5/robot-structural-analysis-forum/error-2110-problem-with-linear-loads/...
Macro converting nodal loads onto force in point loads (for claddings, panels)
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-converting-nodal-loads-onto-force-...
Addin: convert bar's forces to node forces
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-convert-bar-s-forces-to-node-force...
Addin for creating load cases basing on load records from another case
http://forums.autodesk.com/t5/robot-structural-analysis/linear-load-has-not-been-applied-to-the-pane...
Macro for updating panel contour loads
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-updating-panel-contour-loads-f...
Addin for multiplying all load cases records by factor
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-multiply-a-load-case/m-p/6990972#...
Macro for importing uniform panel loads from Excel to Robot
http://forums.autodesk.com/t5/robot-structural-analysis/api-how-to-add-panel-loads-in-excel-format-t...
Macro damping Load table to Excel with single object list
http://forums.autodesk.com/t5/robot-structural-analysis/api-extraction-of-loads-into-excel/m-p/60117...
Envelope of forces at a connection,
https://forums.autodesk.com/t5/robot-structural-analysis-forum/envelope-of-forces-at-a-connection/td...
Macro for updating model geometry considering deformation of selected case
https://forums.autodesk.com/t5/robot-structural-analysis-forum/macro-for-updating-model-geometry-con...
macro for bars strain calculations
http://forums.autodesk.com/t5/robot-structural-analysis/api-why-robot-didn-t-show-the-strain-resulta...
macro for panels strains calculations
macro for nodal displacements in local coordinate system of bars
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-nodal-displacements-in-...
macro for bar end forces as reactions
https://forums.autodesk.com/t5/robot-structural-analysis-forum/local-reactions-api/td-p/13213319
different bars forces tables
https://forums.autodesk.com/t5/robot-structural-analysis-forum/different-bars-forces-tables/td-p/132...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/getting-internal-forces-from-RSA-to-XL-API/t...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Extract-Envelope-Values-with-API/m-p/3413063...
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-max-moment/td-p/4762433
panels results tables
https://forums.autodesk.com/t5/robot-structural-analysis-forum/export-results-arsa-via-api/td-p/3294...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RESULTS-EXPORT-VBA-API/td-p/4337588
https://forums.autodesk.com/t5/robot-structural-analysis-forum/export-results-arsa-via-api/m-p/13209...
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-finite-element-results-for-cqc-com...
Macro for dumping all opened tables in Robot (with all tabs) to Excel
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-dumping-all-opened-tabl...
Macro for dumping active table (with all tabs) to Excel replacing correctly "/"
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-2018-csv-file-on-results-for-pl...
sum of reactions for the slab on elastic ground defined in panel thickness definition
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-sum-of-reactions-for-the-slab-on-elastic...
sum of reactions for the slab on elastic ground defined as planar support
http://forums.autodesk.com/t5/robot-structural-analysis/api-extracting-ground-reactions-results-kz-u...
Import of reactions to new model
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Only-reaction-for-new-model-API/m-p/3659242/...
Export /  import reactions table to Excel
https://forums.autodesk.com/t5/robot-structural-analysis-forum/export-import-reactions-table-to-exce...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addin-for-exporting-reactions-to-...
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-get-reactions/m-p/6575119
Nodes rotation – local axes
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nodes-Rotations-Local-Axes-API/m-p/3459442/h...
THA results to Excel
https://forums.autodesk.com/t5/robot-structural-analysis-forum/tha-results-to-excel/td-p/13253420
FRF results to Excel
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Exporting-modal-harmonic-load-case-getti...
macro for modifying the members list in steel design code groups in table
http://forums.autodesk.com/t5/robot-structural-analysis/api-way-of-modifying-the-members-and-code-gr...
macro for creating Dimensioning Groups using different criterions
http://forums.autodesk.com/t5/robot-structural-analysis/api-get-data-to-create-dimensioning-groups/m...
macro for checking bars membership in groups and steel design groups
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-checking-bars-membership-in-gr...
macro for Member Verification ULS Ratio along bar length
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-member-verification-uls-ratio-...
Verification for the CFT column (Only circular tubular) and run all the optimizations based on construction costs.
http://forums.autodesk.com/t5/robot-structural-analysis/api-cft-concrete-fillet-column-in-robot/td-p...
addins for timber calculations, loads and combinations , EC8 relative displacements generator
http://forums.autodesk.com/t5/robot-structural-analysis-forum/api-addins-for-timber-loads-and-combin...
Addin for Exporting Reactions to Excel V2
Estimation of reinforcement weight for all RC Beams and RC Columns
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-estimation-of-reinforcement-weigh...
(API) macro to send bar forces to excel in certain order
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-or-macro-to-send-bar-forces-to-ex...
(API) macro for changing/multiplying load values by given coefficient
https://forums.autodesk.com/t5/robot-structural-analysis/outils-modification-des-cas-de-charges-par-...
(API) Diaphragmer - work with diaphragms in another way
Exporting map of slab reinforcement
https://forums.autodesk.com/t5/robot-structural-analysis-forum/c-addin-for-robot-2017-exporting-map-...
Storey Stability Index Calculation addin
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-storey-stability-index-calculatio...
Schemator - toolkit to manage External Parameters
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-schemator-the-toolkit-to-manage-e...
Split Arcs - program to split all arcs of a contour, polyline
https://forums.autodesk.com/t5/robot-structural-analysis-forum/arc-slab-on-arc-wall/m-p/11738903#M94...
Sphere - to obtain spherical shapes from simple meshed panels by a translation of the nodes
https://forums.autodesk.com/t5/robot-structural-analysis-forum/translation-shell-modeling/m-p/119987...
new apps
GetPanelWire- small software utility that lets you create panels in place of FEs
https://forums.autodesk.com/t5/robot-structural-analysis-forum/drawing-mesh/td-p/12782386#M2936
GetMainNodes - quickly extract node lists from contour edges
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-get-edge-nodes-from-contours/m-p/...
AutoConnectFE - helps create finite element (FE) models of your base column connections
https://forums.autodesk.com/t5/robot-structural-analysis-forum/how-does-robot-determine-the-parallel...
Header Explorer - Stop searching for where to find column indexes in Robot Structural Analysis
https://forums.autodesk.com/t5/robot-structural-analysis-forum/header-explorer-stop-searching-for-wh...
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Replies (0)
