Macro for updating model geometry considering deformation of selected case
Konrad.O
Autodesk Support Autodesk Support
Message 8 of 8
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Macro for updating model geometry considering deformation of selected case" topic:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Deformed-geometry-update/m-p/4905994#M22...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (7)
Message 1 of 8
I am not sure if Robot can do this.
I need to do an analysis on a "Deformed structure" to model Initial Imperfection. What I previously did on Lusas is that I set up a non-deformed model, applied loading to the model until the required deformation is achieved, then save the deformed geometry (without lock-in stresses) for later use.
Cheers
sunwaymas
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 8
Thank you. This is exactly what I wanted to do.
It means Robot can't do it by default...??
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Can not do it by default
Rafal Gaweda
Message 5 of 8
Thanks Rafal 🙂
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
I found it in my drawer 🙂
Maybe enough for you.
This macro updates model geometry taking into account deformation of selected case
Rafal Gaweda
Message 7 of 8
Hi Rafal,
Thank you so much 🙂
