Different bars forces tables
Konrad.O
Autodesk Support Autodesk Support
Message 14 of 14
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Different bars forces tables" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/getting-internal-forces-from-RSA-to-XL-API/t...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Extract-Envelope-Values-with-API/m-p/3413063...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (13)
Message 1 of 14
se2p
I have tried without noticeable success to write some code that could give me MAX and MIN bar forces values in several sections (for example spaced by 20cm) for a group of load cases or for a group of normal combinations (not code combinations) and write them down in Excel. In my model I have some vehicle type load cases so the code should work for them to.
Is it possible for you to provide me some code example on how to do this?
One good feature would be to detect the current bar selection on Robot View and extract those bars numbers and forces in several sections. Is it possible to do this?
Thank you
Adriano
Message 2 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 14
result to excel
result> forces (reaction ... etc)>
in table - context menu (left mouse click) CONVERCION TO EXCEL (CSV) FORMAT
Message 4 of 14
se2p
Thank you, but I am interested in extracting results trough API.
Rafal link should do it
Message 5 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
One remark: ValueEx works also for moving load cases so small modification in code to allow one to read such results
File attached.
Rafal Gaweda
Message 6 of 14
Dear members,
I would like to know if someone can share a excel sheet (VBA) to extracte the internal forces from all the bars of my structure. I just need the maximum internal force in the bar, not the values at the bottom or top of the bar (extremes nodes of the bar).
The internal forces that i need are: N, My,Mz;Vy;Vz (i dont need torsion).
I also want to have the possibility to choose all (or just one) the loads cases that i previously had defined in my structural model.
Thank you and regards,
fmp
Message 7 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have you checked the forum ?
Rafal Gaweda
Message 8 of 14
Yes, I have found many excel sheets, but none of them had all the the internal forces that i need (N,My,Mz;Vy;Vz) and also i don't know if there are new updated excel sheets (possible minor bugs corrected).
Message 9 of 14
I have found a excel sheet that almost does what i want, the only problem is that some internal forces are missing, in this case i need N,My,Mz;Vy,Vz.
Message 10 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try this
Rafal Gaweda
Message 11 of 14
Dear RG_Adsk
I want create model in RSAP from excel
And Get Result In RSAP to Excel
please guide me how to do?
Does not need to learn VBA? or C #?
Message 12 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
If you want to use Excel - use Excel VBA.
Rafal Gaweda
Message 13 of 14
Yes Thaks you
I'd love to use VBA for this work
Modeling in RSAP from excel use VBA
Please guide for me
