API Tutorial
API Tutorial
Konrad.O
Autodesk Support Autodesk Support
Message 26 of 26
API Tutorial
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived API Tutorial topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Tutorial/td-p/3939601
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (25)
Message 1 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
Install SDK and look for Tutorial.
I am also attaching API tutorial here.
Rafal Gaweda
Message 2 of 26
yes i am searched This file in folder ROBOT SDK
can you guide for me a tutorial API for ROBOT as video?hi
I want a video for clarity
I asked for more: I want use Visual studio 2012 C# for program ROBOT API ?
Thanks you very much
Message 3 of 26
you don't want much, do you huyxpkiss...........?
Message 4 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
You can find a few C# VS 2010 projects on this forum.
Rafal Gaweda
Message 5 of 26
Please, show me a clip about write addin in robot by C#, thanks you !
Message 7 of 26
teixeiranh
Sorry to ask but, is there a way to list all of the object data type available in RSAP?
For example, if I want to define a node I can write Dim Node as IRobotNode and them set it. IRobotNode is a data type. Which are the other ones?
Are they all used in the examples given?
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 8 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
Whole documentation in "Robot API.pdf" in SDK
Rafal Gaweda
Message 9 of 26
teixeiranh
You are absolutely right! Stupid question! Thank you!
Cumprimentos,
Nuno Teixeira
Message 10 of 26
teixeiranh
Sorry to bother! Is that "RobotApi.pdf" in DSK different than the API tutorials that we can unzip that you have pasted in the first comment of this thread?
Message 11 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
Let's say 99% in this pdf comparing to 2015 version.
Rafal Gaweda
Message 12 of 26
Is there any way to access the Frame Generator by API?
regards
Message 13 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
Frame Generator is addin using Robot API. It has no its own API.
Rafal Gaweda
Message 14 of 26
Its a very helpful API tutorial.
Message 15 of 26
Is there any way to create and modify non linear properties for supports using VBA script in Excel? I am modelling bridge abutment with piles and horizontal spring supports on piles. Adding NL parameters to supports using standard way is horribly time consuming (creating individual NL models -> assigning each model to selected direction of one support -> accepting changes -> robot is freezing for several seconds -> one support is done!). Changing 80 supports for one abutment took me more than 4 hours.
Thanks for any help.
Marcin
Message 16 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 17 of 26
Hi Rafal, I reviewed the APITutorial but do not see a list of all data type. Do you mind attaching the pdf you mentioned?
Like the other user, I am looking for a complete list of datatype, such as IRobotNode etc. I am also looking for some help to show me what functions there are. By functions I mean robapp.Project.Structure.Nodes.GetAll() is a function. What else can I do with .Nodes? And .Bars? And what others are there?
Thanks a lot in advance.
Danny
Message 18 of 26
Rafal.Gaweda
Autodesk Support
Autodesk Support
install SDK directly from media : \x64\Tools\RSASDK\RSA_SDK.msi
and the path C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\SDK\ to whole SDK, documentation, tutorial
Rafal Gaweda
Message 19 of 26
Thank you Rafal. I am a corporate user so do not have the media myself, but I will ask the IT department for help. Will let you know if we have trouble.
Danny
