Ordinary round coordinates addin
Konrad.O
Autodesk Support Autodesk Support
Message 12 of 12
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived Ordinary round coordinates addin topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-message-API/m-p/3878461/highlight/true...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (11)
Message 1 of 12
HoshangMustafa
Hi
Please find the attached file. What is the eroor and how it is solved? I tried The Edit-Correct command, but it didn't solve the error.
http://we.tl/mWtimotwdF
Message 2 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Diaphragms can be assigned to flat horizontal panels. None of 1264to1266 panels is horizontal
Rafal Gaweda
Message 3 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 4 of 12
HoshangMustafa
Hi
Thanx Rafal. How can I get this table? It looks ok in the polyline contour dialog. I appreciate if you could help this.
Message 5 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 6 of 12
HoshangMustafa
Hi Rafal
Thanx. I appreciate your solutions. Please find the attached files. I changed the walls to panels to reduce calculations and used RoundUpDown_2.exe and ran the calculations but there is still the error. Is there a way to split the walls into two parts according to your suggestions?
Message 7 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Round Up or Down will not help you because some coordinates of the same panel points are above 1.45 , some below. Use ordinary "round" - addin (attached) This will correct (set correct tolerance before rounding)  1264 1265  but  1266  is not horizontal so it must be calcaulated with Shell calculation model.
BTW why not to use Shell for all of them?
Rafal Gaweda
Message 8 of 12
HoshangMustafa
Hi Rafal
Please find the attached file. Is it ok?
1- soil pressure
2- water pressure
3- modelling of walss, floors, foundations
every thing.
http://we.tl/8SNq2nSEMA
Message 9 of 12
HoshangMustafa
Hi
1- soil pressure
2- water pressure
every thing.
If the soil had a swelling pressure of about 35kn/m2, how this can be applied?
Message 10 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 11 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not undestand.
New case? Add this load to walls?
Rafal Gaweda
