Bars to rigid links converter add-in
Konrad.O
Autodesk Support Autodesk Support
Message 15 of 15
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Bars to rigid links converter" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Bars-to-links-API/m-p/3743220/highlight/true...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (14)
Message 1 of 15
Alec1
Hi everyone.
I would like to know if anyone can tell me if it is possible to automatically transform a series of bars into links.
Alex
Message 2 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example macro attached.
Selected bars in Robot will be converted onto full rigid links
Rafal Gaweda
Message 3 of 15
Alec1
Thank you very much!
Now I am still a new user of robots, but I would like to know if I can create by myself an application
like the one you sent me.
Is there a manual to learn?
Message 4 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 5 of 15
Romanich
Hi Rafal,
Could you confirm that now it is impossible to create trough API multiple rigid links with the common master node?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 6 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Of course it is not possible because it is not possible to create such RL in Robot itself.
Rafal Gaweda
Message 7 of 15
Romanich
Really?
I'm trying to do the same by API
Roman Zhelezniak
Message 8 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is one RL with 4 slave nodes....
Rafal Gaweda
Message 9 of 15
Romanich
I have found solution. Thanks!
Roman Zhelezniak
Message 10 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
        Dim RLS As RobotNodeRigidLinkServer
        Set RLS = RobApp.Project.Structure.Nodes.RigidLinks
        RLS.Set 7, "3to6", "rl_fixed"
Rafal Gaweda
Message 11 of 15
mgaafar
Hi Rafal,
            Can you update the API macro to create Compatible nodes between bars end nodes instead of Rigid links?
I have about 1000 nodes that need to be linked in a nonlinear behavior and I could not find away other than copying the nodes with the Drag option so as to create bars, and then use the API to create a compatible link between the end points of each bar.
Just for your info, I am using it with Solid/volumetric structure design module.
Message 12 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @mgaafar
I am afraid it can not be done by API.
Using API , the compatible nodes can be generated only in bars common node  + specifying bars which should belong to new node created.
Rafal Gaweda
Message 13 of 15
cool.stuff
@Rafal.Gawedacould you please explain how this sheet works?
I have selected a closed boundary of bars in RSAP and run your macro but I always get the message: "Decide - RL will not be created".
Could you explain or create a video please? Thanks!
Message 14 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
This macro works for only ONE selected bar.
Rafal Gaweda
