Bars to rigid links converter add-in
Konrad.O
Autodesk Support Autodesk Support
Message 15 of 15
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Bars to rigid links converter" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Bars-to-links-API/m-p/3743220/highlight/true...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (14)
Message 1 of 15
Alec1
Hi everyone.
I would like to know if anyone can tell me if it is possible to automatically transform a series of bars into links.
Alex
Message 2 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example macro attached.
Selected bars in Robot will be converted onto full rigid links
Rafal Gaweda
Message 3 of 15
Alec1
Thank you very much!
Now I am still a new user of robots, but I would like to know if I can create by myself an application
like the one you sent me.
Is there a manual to learn?
Message 4 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 5 of 15
Romanich
Hi Rafal,
Could you confirm that now it is impossible to create trough API multiple rigid links with the common master node?
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 6 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Of course it is not possible because it is not possible to create such RL in Robot itself.
Rafal Gaweda
Message 7 of 15
Romanich
Really?
I'm trying to do the same by API
Message 8 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is one RL with 4 slave nodes....
Rafal Gaweda
Message 9 of 15
Romanich
I have found solution. Thanks!
Message 10 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
        Dim RLS As RobotNodeRigidLinkServer
        Set RLS = RobApp.Project.Structure.Nodes.RigidLinks
        RLS.Set 7, "3to6", "rl_fixed"
Rafal Gaweda
Message 11 of 15
mgaafar
Hi Rafal,
            Can you update the API macro to create Compatible nodes between bars end nodes instead of Rigid links?
I have about 1000 nodes that need to be linked in a nonlinear behavior and I could not find away other than copying the nodes with the Drag option so as to create bars, and then use the API to create a compatible link between the end points of each bar.
Just for your info, I am using it with Solid/volumetric structure design module.
Message 12 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @mgaafar
I am afraid it can not be done by API.
Using API , the compatible nodes can be generated only in bars common node  + specifying bars which should belong to new node created.
Rafal Gaweda
Message 13 of 15
cool.stuff
@Rafal.Gawedacould you please explain how this sheet works?
I have selected a closed boundary of bars in RSAP and run your macro but I always get the message: "Decide - RL will not be created".
Could you explain or create a video please? Thanks!
Message 14 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
This macro works for only ONE selected bar.
Rafal Gaweda
