Header Explorer - Stop searching for where to find column indexes in Robot Structural Analysis
Hello everyone,
Meet Header Explorer, a tool designed to save you from endlessly hunting down “magic numbers” in the forums or API documentation.
If you often need to extract and customize tables in Robot Structural Analysis via API, and you're tired of wasting time trying to find the right column headers, this app is made for you!
Fast header scanning
- Automatically scans and lists all available column headers (from index 1 to 10,000).
- Displays the associated index for direct access to data fields.
Intuitive search
- Instantly locate headers with a dynamic, real-time filter, generating 35 codes per second.
- multi-column search by making any list with keywords separated by semicolons
- Double-click a result to copy it directly to your clipboard.
Multilingual support
- Fully compatible with all printout languages supported by Robot (English, French, German, Spanish, etc.).
- Easily switch between language versions of headers for better clarity.
Clean, modern interface
- Sleek dark mode for enhanced visual comfort.
- Fully resizable and customizable window layout.
Optimized performance
- Visual progress indicator during scanning.
- Scan can be cancelled at any time by pressing the Escape key.
Is Robot Structural Analysis installed on your machine?
Just launch Header Explorer, choose your preferred language, and click Scan.
The application can be stopped at any time by pressing Esc or clicking Exit.
A full scan takes around 5 minutes, but you can begin searching as soon as the scan starts.
Best Regards
Last updated on 08/06/25 Version 1.1.2, .NET Framework 4.8.
