Macro with incremental buckling combination
Konrad.O
Autodesk Support Autodesk Support
Message 8 of 8
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Macro with inceremental buckling combination" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Buckling-combination/td-p/4331271
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (7)
Message 1 of 8
Can Robot do a buckling analysis of a shell structure with several combinations BUT to only give the critical load with the augmentation of only one load from combination (example, a structure with self-weight and wind action, give critical load only on respect to the increase of the wind load)?
Thank you
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Once I had such API macro.
I will try to find it.
Rafal Gaweda
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have fun!
Attached
Rafal Gaweda
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Update 1
Avoiding launching calculations several times - suitable for larger models.
Rafal Gaweda
Message 5 of 8
I have tried the Macro but it doesn't seem to work.
My intention was to keep one load case constant (say the selfweight) and determine the buckling factor for a live load case. The Macro seems to give the buckling factor for both. For example;
1.0 x Basic case + 1.0 x Case for increment  ----- say buckling factor of 15 (the Macro considers 15 time the Basic case + 15 times the Case for increment).
Thanks.
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
The purpopse of this macro is:
"....BUT to only give the critical load with the augmentation of only one load from combination"
Rafal Gaweda
Message 7 of 8
Hi Rafal,
I thought the intention is to;
Cheers.
