Converting nodal elastic support generated from planar support onto nodal support
Konrad.O
Autodesk Support Autodesk Support
Message 10 of 10
Konrad.O
Autodesk Support
Autodesk Support
WIP
A copy of the archived "Converting nodal elastic support generated from planar support onto nodal support" topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Editing-nodal-spring-values-API/td-p/3901799
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (9)
Message 1 of 10
Hello.
I'm trying to model a footing in a volumetric model, and the soil stiffness is modeled trough springs in the bottom face of the footing via planar supports, so that the area of influence of each node is considered, but, I would like to run some experiments by editing the nodal spring stiffness according to their distance from the center of the footing. I wanted to work with the corresponding tables, but in the node tables, i'm not finding the calculated spring stiffness from Robot! Is there any way that i can see and edit these values via table? I could do it one by one, but I would rather not do that..
Thank you!
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
You can see values in Nodes or Reactions table
These values are not editable but you can create (convert these values) as   \to nodal supports and then play with the values in Supports table.
Example Macro converting planar supports (considering only kx ky kz) attached.
Rafal Gaweda
Message 3 of 10
Works like a charm! Thank you 🙂
Message 4 of 10
kamlinmoodley
How do we get the column for "Uz" in the reactions table? My table only has the first 6 columns as per attached pic
Message 5 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
RT.AddColumn (141)
Add such column to table
Rafal Gaweda
Message 6 of 10
kamlinmoodley
How? I cannot see the option in the attached..
Message 7 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 8 of 10
kamlinmoodley
This does not represent the stiffness of the springs (kN/m) but instead shows displacement (mm)?
Message 9 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
