(API) macro for creating panel profiles from bars
Rafal.Gaweda
Autodesk Support Autodesk Support
Rafal.Gaweda
Autodesk Support
Autodesk Support
It should work for most of steel database sections,and most of  parametric and tapered steel sections
Assuptions:
- panels are created in mid  "walls" planes
- thicknesses should be corectly recognized and applied
- tapered thickness (of defined for tapered member) is not considered
Example:
Rafal Gaweda
Rafacascudo
Very nice Rafal!!
it works even for tapered pipes!!
Is there a way to control the number of segments that form the circle?
Rafael Medeiros
Rafal.Gaweda
Autodesk Support
Autodesk Support
Did my best 🙂
Circle segments : edit macro and find
Ndiv parameter for quarter of the circle
If (R <= 0.2) Then
    NDiv = 3
Else
    If (R > 0.2 And R <= 0.4) Then
        NDiv = 4
    Else
        NDiv = 5
Rafal Gaweda
t.sautierr
brilliant !
umut.akparlar
Hi @Rafal.Gaweda
Is it possible to implement this feature to RSA, could you kindly share this feedback with development team?
