(API) Robot 2018 - CSV file on Results for Plates
Message 1 of 11
I am starting to use Robot 2018 and I notice that the conversion to CSV file from the table of "Results for Plates" is not following the same format as in Robot 2015. The character that is doing the separation between "Panel", "Node" and "Case" is "/" instead of ";".
This is a beat boring, because when I need to open the csv file in excel, the numbers of the panel and the node appear at the same column and cell.
Is there any way in Robot 2018 to continue to export this table in the same format as in Robot 2015?
Thank you.
Kind regards,
David
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
My advice is to open csv file in Notepad and replace / by ; and save the file
Rafal Gaweda
Message 3 of 11
Thank you for your reply, but a bit tricky for a CSV file which goal is to create a text file with strings separated by "," or ";"!!
If it was working fine in the previous versions, why it has changed?!
David
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I guess it was changed to have exactly the same table look like in Robot. First column contains "/" sign in Robot.
Rafal Gaweda
Message 5 of 11
hi,
Worse than the change made is the autodesk support justification, totally unacceptable.
NMV
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'd say it is hard to understand why Microsoft allows you to replace /space with another character in e.g. Notepad but doesn't allow you to set it as a delimiter in Excel Smiley Wink
Anyway the solution proposed by Rafal is not that hard to execute:
Artur Kosakowski
Message 7 of 11
StefanoPasquini6790
If I'm not wrong, in excel you can set more than one limiter in the csv data importing, so you can use two or three of them, including an "user defined one" . I do this everyday.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI Stefano,
The only issue is that if you set / then you will 'corrupt' units as well Smiley Sad . This is why I introduced notepad in the process as I wasn't able to set /space as the 'used defined one' in Excel Smiley Mad
Artur Kosakowski
Message 9 of 11
I keep my opinion that RSA 2018 has a "minor bug" in the conversion to a CSV file that should be corrected in the next service pack, because it doesn't make any sense spend time in opening  the csv in the notepad then replace "/" by ";" except in the units, save the file and then open it in Excel, even more when this option of convert to CSV was working fine and correctly since Robot 17 (2002)!!
David
Message 10 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I have forwarded your request to the development team. I hope that for a moment the workaround I provided will be acceptable for you.
Artur Kosakowski
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi All
I have prepared (in fact I have modified existing on forum) macro for dumping active table with all tabs to csv \ txt replacing correctly "/" and keeping units.
Macro attached.
Feel free to modify it if needed.
PS
Sometimes it may not run on Plate and Shells Results table \ Envelope tab
Rafal Gaweda
