(API) Diaphragmer - work with diaphragms in another way
Romanich
Mentor Mentor
Message 1 of 28
Romanich
Hello everyone,
As you might know from this post https://forums.autodesk.com/t5/robot-structural-analysis-forum/diaphragm-problem-to-be-corrected/m-p...
there are several issues with diaphragms in Robot:
  1. The master node for the diaphragm is located in the geometric center of the slab. The diaphragm master node should be in the projected center of gravity of the story on the floor slab level.
  2. If in the model we have more than one floor slab in the same level, the diaphragm will be created for each slab individually. The diaphragm should be one for each level.
  3. It is not possible to assign loads to the master node and get results (eigenvectors etc.). Also, this node is not considered in FE mesh. The master node should be accessible as a common regular node in Robot.
While Robot development team is still sleeping waiting for financing improving performance, I would like to present the solution to the above-mentioned issues – the Diaphragmer.
The Diaphragmer is now live in the Autodesk App Store:
https://apps.autodesk.com/RSA/en/Detail/Index?id=8768390536116652588&appLang=en&os=Win64
How to use:
Read this article
Please watch this short video with a live demonstration of Diaphragmer possibilities:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (27)
Message 2 of 28
mustafahesenow
Bravoo @Romanich
This really very helpful tool.
I vote for you to be one of the best developer for RSA.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 3 of 28
StefanoPasquini6790
Romanich=Best Robot Developer of the world!!!
Impressive and useful tool, that demonstate a lot of things:
1) Romanich is the best, absolutely the best!
2) Robot is the best, because give to simple user (but Roman is not a simple user, but a genius!!!) the opportunity to use Robot Engine to develop itselfs powerfull tools. No other software have this plus;
3) adsk, after about ten years from the acquisition of Robot still not understood this power and let the user, instead of itself, develop the software...
adsk, keep Robot alive and up to date!
Romanich, tons of compliments for your tool.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 4 of 28
Rafacascudo
Congrats Roman !!!
Our SpidEEr man , Master of Rlinks and other additional atributes.
Rafael Medeiros
Message 5 of 28
Muhammed.OPERA
Excellent Mr. @Romanich Smiley Happy
That is absolutely awesome
After the Spider comes the Diaphragmer, Really you are the API Master.
Thanks for those very useful tools 🙂
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 6 of 28
wassim_said_said
Great Tools Roman, and very nice work.
Congrats,
Wassim Said
Message 7 of 28
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Romanich
Excellent job. Thank you very much.
Artur Kosakowski
Message 8 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Romanich
Hats off, Roman!
Added to our addin list.
Rafal Gaweda
Message 9 of 28
Refaat
Dear Roman
Thank you so much ,
As RSA users, we are very impressed by this wonderful effort. You are really one of the main pillars of improvement ROBOT capability.
Keep up the good work!
 Refaat
Message 10 of 28
Hi @Romanich
Congratulations for this powerful tool you created.
I tried to install it on my PC , but I got this shown message;
Message 11 of 28
Romanich
Hi @Anonymous,
Please try to run installation as an Administrator.
Roman Zhelezniak
Message 12 of 28
me1205377
greetings, i installed the addin and it is working but the issue is that only working for  the first defined floor  but not the other stories. diaphgramer.JPG
moustafa elgaar
Message 13 of 28
Romanich
Hi @me1205377,
It's hard to say without having the model.
Roman Zhelezniak
Message 14 of 28
me1205377
hi Mr. Roman
i am using version 2015 could this be the issue
please find the attached model
has similar problem
moustafa elgaar
Message 15 of 28
me1205377
model attached
moustafa elgaar
Message 16 of 28
Romanich
The Diaphragmer was updated to 1.1 version (the first post in this topic was modified):
 - now it is possible to use any Excel file (template can be generated in one button click)
- Certificate Romanich.pfx was updated for 10 ten years
I tried to publish the Diaphragmer in the official Autodesk App Store but this attempt was not successful - too many rules and unnecessary requirements.
Roman Zhelezniak
Message 17 of 28
structural.engineer79
Thank you very much
Its supporting inclined slab or only horizontal slab
many thanks
Message 18 of 28
Romanich
Hi @structural.engineer79 ,
Only horizontal slabs
Roman Zhelezniak
Message 19 of 28
Romanich
Finally, the Diaphragmer is now live on the official Autodesk App Store!
Roman Zhelezniak
Message 20 of 28
@mustafahesenow  ; @Romanich
When I use the Diaphragmer, the "Total mass" verification (in "Dynamic analysis Results") does not work. I get much less "total mass" when I put the diaphragm centers at locations calculated with the Diaphragmer.
When the diaphragm is created automatically by Robot, the "Total mass" is matching with the actual mass of the structure i.e. with load cases used in modal analysis.
For this check I used only 2 load cases in modal analysis. DL1 (selfweight) and DL2 (superimposed dead). In mass conversion I have put only DL2 as DL1 is selfweight and is converted automatically. For this check LL1 is not participating in modal analysis.
Am I doing something wrong?
Files attached. As this website has not allowed me to upload the Robot files, I have put both Robot files in this folder on my google drive:
https://drive.google.com/drive/folders/1JCHwA6z8GFxuOp1YarH8H1oSqLHX37xw?usp=sharing
Alex
