- Mute
- Permalink
- Report
Hello everyone,
As you might know from this post https://forums.autodesk.com/t5/robot-structural-analysis-forum/diaphragm-problem-to-be-corrected/m-p...
there are several issues with diaphragms in Robot:
- The master node for the diaphragm is located in the geometric center of the slab. The diaphragm master node should be in the projected center of gravity of the story on the floor slab level.
- If in the model we have more than one floor slab in the same level, the diaphragm will be created for each slab individually. The diaphragm should be one for each level.
- It is not possible to assign loads to the master node and get results (eigenvectors etc.). Also, this node is not considered in FE mesh. The master node should be accessible as a common regular node in Robot.
While Robot development team is still sleeping waiting for financing improving performance, I would like to present the solution to the above-mentioned issues – the Diaphragmer.
The Diaphragmer is now live in the Autodesk App Store:
https://apps.autodesk.com/RSA/en/Detail/Index?id=8768390536116652588&appLang=en&os=Win64
How to use:
Please watch this short video with a live demonstration of Diaphragmer possibilities:
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
