Export / import reactions table to Excel
Konrad.O
Autodesk Support Autodesk Support
Message 10 of 11
Konrad.O
Autodesk Support
Autodesk Support
A copy of the archived "Export / import reactions table to Excel" topic:
http://forums.autodesk.com/t5/robot-structural-analysis/api-for-exporting-reactions-to-excel/td-p/53...
Konrad Ociepka
Senior Product Owner - Structural Analysis
Replies (10)
Message 1 of 11
 As there's no implicit option in Robot to export reactions to Microsoft Excel (.xlsx format), only (.csv) format
this addin will export reactions to Excel
Message 2 of 11
StefanoPasquini6790
Very useful and friendly.
Great job, thank you
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Nice.
Added to our list
Rafal Gaweda
Message 4 of 11
StefanoPasquini6790
Hi everyone,
there is some issue in the API.
the columns of table don't show the correct value, to a little test it happen that in FX column I have "CQC" and all the values shift in the next column. To have a clearest focus on this topic show the image below:
However, this is a very nice tool.
Greetings
PasProStudio
Message 5 of 11
Thanks for the feedback.
a small change to fix such a problem (the name of the load combination contains "/" in it, please tell me if the problem still exists.
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Small macro doing that ,attached
(if it is not properly open in Excel, open VBA editor and play with changing separators characters, relevant code marked in macro)
Rafal Gaweda
Message 7 of 11
AhmedZA
this is a very useful tool
thanks Mohammed
Message 8 of 11
Mohammed_Ata
Dear, all
First of all, great thanks for efforts.
How can i select one case and export its reactions to excel only ? The default is to export all cases!
Message 9 of 11
Message 11 of 11
princesif
are you create it with C#?
