Unsolved posts challenge: Week May 6th, 2024
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Check out last week's most popular posts that haven't received an accepted solution yet. If you have a solution for any of these topics, we encourage you to share it. Remember, marking a post as an "Accepted Solution" helps the wider community find answers more quickly. Thank you for your contributions!
Topic
Published Date
Exporting Points with layer information-other options
06-May-24
EXPORTCIVILDRAWING
07-May-24
When the client makes pickles out of your project 🙂
07-May-24
Change the Character/Sign of Station in the Corridor Solids Extracted file.
07-May-24
Create pipe using a profile
07-May-24
Cul De Sac Folding/ overlap
07-May-24
Export Dynamic Block to IFC
07-May-24
material cut and fill
06-May-24
Point to Point Label Style Using Grid Distance Produces An Error (???)
07-May-24
Profile View Data Grayed out - I can't split my profile view
06-May-24
recovering .pkt file from .atc file
07-May-24
Create multiple sections for a corridor
07-May-24
Georeference dxf in Civil3D not at correct position after export
09-May-24
getting a read only dialog box?
07-May-24
CANT LABEL FOR ALIGNMNET IS NOT UPDATING
07-May-24
how to edit section station.
07-May-24
New drawing "locks" when opening
06-May-24
Plan and profile
10-May-24
Gravity Network Pipe Wall Thicknesses
07-May-24
movebak being sporadically ignored in 2025
06-May-24
Surface: exclude great height drops
08-May-24
Can anyone help me to get the ??? to display in a curve table? for line/curve features
09-May-24
Corridor surface does not match assembly
08-May-24
Creating a slab and edge beam
06-May-24
Survey CAD Tech
09-May-24
VB Script in Property Set not work when restart Civil 3D or computer
06-May-24
recovering .pkt file from Atc file
07-May-24
Tool Palette - Feature Line commands
10-May-24
Corridor slopes
08-May-24
Very disturbing xref bug
08-May-24
07-May-24
Do attributes and Fields work the same way?
08-May-24
use more than 1000 points in Subassembly Composer for p1 class
11-May-24
Generar Poligono 2D con dimensiones de sus lados y área total, sin conocer angulos internos
08-May-24
GET GUID FOR 3D OBJECT IN CIVIL 3D
10-May-24
Metro Project - Pier details extraction (Easting, Northing, Elevation and Stations)
08-May-24
Problems with "phantom" Pressure Pipe in IFC file
09-May-24
Editing Surfaces in Object Viewer
10-May-24
Surface Generation with LiDAR - Smoothing
10-May-24
'Add current folder to places' where is the file created saved?
10-May-24
Extracting catalogs from c3d file
11-May-24
Pipe labels vanishing act in profile views
08-May-24
Pipe profile
10-May-24
Show profile in the plan view
10-May-24
Sub criteria
10-May-24
Can not generate line or curve tables by window selection
10-May-24
MULTIPLE SECTION VIEWS' HEIGHT VARIATION
10-May-24
Pipe in the profile view
10-May-24
Vertical profile curve labels
09-May-24
Toolspace and External References windows not keeping their original positions on start up
08-May-24
Data Shortcuts Invalid Reference Warnings when e-transmit.
08-May-24
Edit base source FG will re-saving the sheetset update the surface in each?
09-May-24
PRESSURE NETWORK ADDING FLANGED FITTING BROKEN
08-May-24
bande de dévers
08-May-24
08-May-24
Managing Data shortcuts over BIM 360 with several third party designers
09-May-24
Civil 3D and Autodesk construction Cloud connection
13-May-24
corrupted structure labels
08-May-24
Infrastructure Parts Editor for Piping - Documentation and examples
10-May-24
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
