I created a corridor surface from the corridor of assembly. However, the corridor surface does not match the assembly sections which should be the channel alignment as show below.
Can anyone show me how to adjust the corridor surface to match the channel? I also attach the dwg. file.
As this will result in incorrect volume calculation later on.
Thanks.
Your corridors requires subassembly (subassemly1) that are not in my system....
Did you use any custom subassemblies with Autodesk Subassembly Composer? If yes, please zip them and attach them.
I found 2 corridors each one has a corridor surface.
Can you give me more details of your problem?
I snapshot could help. I did not understand the problem with the above snapshot
Thanx
I have problem with the corridor surface (Tin surface: DS 2) for Ch. 1+900 to Ch. 3+450 subassembly as shown below.
At the moment, the corridor surface DS 2 is the green area whereas it should be the red area as below. I don't know why the surface area extends to be the green one, may be due to the curve shape of the corridor. I didn't have this problem with a straight corridor.
From your image it seems like your corridor surface does not have a boundary. Adding it might solve the issue.
Yes, as @Jeew-m you have problem with your corridor surface boundary for the surface DS2.
If you are not able to make quick + automatic corridor boundary you can try to add restrictions during the build of your surface. See the below screenshots.
Hello @kien_nguyenFVYJ8,
I understand that you are facing an issue with creating corridor surfaces in Civil 3D. This is a common problem and can be solved by following these simple steps:
1. Select the corridor surface that you want to work on.
2. Determine the maximum angle you want to connect by line with a point.
3. Implement the fix by following the instructions.
Let me know if you need any further assistance.
Hi Kien,
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! Have you had a chance to review the suggestions our experts provided?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
