I forgot to change the character/Sign of the Station of Alignment, and I Extracted the 3D soilds and have worked a lot on it.
Now i have to change the character/Sign of the Station of the solids from "+" to "." , So Basically i have to Change it rom Chainage to Km.
PS; take a look at the image attached
Hi, to be able to change the Station Delimiter Character (the +), in Toolspace > Settings Tab > right-click on your Drawing > Edit Drawing Settings > Ambient Settings tab > Stationing:
Unfortunately, you're limited to the options you can change it to, but you could set it to "<none>".
Hi @Varun_H-K ,
Let's follow step by step below.
1. Go to the Manage tab and create a new style
(See picture below)
2. Click to New Style then check to the box in step 5
(See picture below)
3. Add new Item and write anything that you want in step 7
(See picture below)
4. Continue step by step 8-9-10-11-12
(See picture below)
This is your result,
Is that you need?
thanks for the try @buinhuthuong @v-silvestre
am looking for something like this
I got this by going back to the design file, then change its alignment label to "Decimal" format and "None" character.
What i am looking for is, instead of going back to that design file i want to change it in the solids file
Hi @v-silvestre
Your information is created by default in Civil 3D and locked, we can not modify those property set definitions. You can always create a new property set and apply it to the same corridor solid though!
Hi Varun,
Welcome to the Autodesk Community! Have you had a chance to review the suggestions our experts provided?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
