Creating a slab and edge beam
Ray.bongalon
Ray.bongalon
Hi all. I would like to have your opinion on this matter. I have created the image attached using Revit to show my intent - one alignment/assembly (red) for the slab and another alignment/assembly (blue) for the edge beam. Is there another way to do this with just one alignment? The red alignment can be curved, the reason why I separated it from the blue alignment. Thank you.
Ray.bongalon
This is not an actual project. I want to expand my knowledge of Civil 3D. Cheers.
fcernst
Yes.. you could do that in one Corridor with two Assemblies and two Baselines ..
Or make one subassembly in SAC with typical flange type shapes and a curved portion .. parabolic or circular..for the red line..
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Ray.bongalon
Thanks for your suggestions.
lim.wendy
Hi Ray,
Welcome to the Autodesk Community! Have you had a chance to review Fred's suggestions?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
