Inventor Nastran 2026.0 list of changes
John_Holtz
Autodesk Support Autodesk Support
Message 1 of 1
John_Holtz
Autodesk Support
Autodesk Support
Inventor Nastran 2026.0 has been released. This is my list of changes that I believe are important to users, taken from various sources.
To install the update, go to manage.autodesk.com and click “All Product and Services” (on the left or across the top). Inventor Nastran 2026 needs to be installed after installing Inventor 2026.
Item
Change in version 2026.0
1
Improved solve time for faster execution by decreasing the time to generate the Nastran file.
2
Fixed a crash that occurs when right-clicking or double-clicking on a branch of the Model Tree multiple times.
3
Fixed an issue in an explicit dynamics analysis that results in GARBLEDFILE error. (See An explicit dynamics analysis ends with an error "pmo_error: GARBLEDFILE" in Inventor Nastran for details.)
4
Resolved issue where Inventor crashed after the analysis (when displaying the results) when the sub-case name included the percent symbol %.
5
Resolved issue where none of the dialogs could be opened after using the Check Quality for Mesh tool. (See Inventor Nastran 2025 crashes when using Check Quality for Mesh for details.)
6
Load applied to an edge now creates a uniform distribution. (See Force applied to an edge is an approximation in Inventor Nastran for details.)
7
Fixed the issue where the "Meshing Cancelled" warning message appeared when generating a mesh from the "Mesh Table".
For previous releases, see
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Replies (0)
