Inventor Nastran 2025.2 list of changes
Inventor Nastran 2025.2 has been released. This is my list of changes that I believe are important to users, taken from various sources.
To install the update, go to manage.autodesk.com and click “All Product and Services” on the left. Or use the app Autodesk Access that is installed on the computer to update from 2025.0 or 2025.1.
Item |
Change in version 2025.2 |
1 |
It is now possible to copy mesh controls from one analysis to another within the same Inventor model. |
2 |
Entries under Loads, Constraints, Mesh Control, and Contacts in an analysis can be re-ordered with drag and drop operation. |
3 |
The Spring Connector dialog now displays all six (6) stiffness input so that users do not miss entering the required values. |
4 |
“Load > From Output” now works to get temperature and pressure results from a CFD analysis. |
5 |
Improved the generation of Nastran files with many loads and constraints for certain models. |
For previous releases, see
- Inventor Nastran 2025.0 list of changes
- Inventor Nastran 2024.3 list of changes
- Inventor Nastran 2024.2 list of changes
- Inventor Nastran 2024.0 list of changes
- Inventor Nastran 2023.2 list of changes
- Inventor Nastran 2023.1 list of changes
- Inventor Nastran 2023.0 list of changes
- Inventor Nastran 2022.2 list of changes
- Inventor Nastran 2022.1 list of changes
- Inventor Nastran 2022.0 list of changes
- Inventor Nastran 2021.2 list of changes
- Inventor Nastran 2021.1 and 2021.1.1 list of changes
- Inventor Nastran 2021.0 is available
- Inventor Nastran 2020.2 list of changes
- Inventor Nastran 2020.1 list of changes
- Inventor Nastran 2020 list of changes
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
