Cannot get Eagle to run on Ubuntu 22.04 LTS Jammy Jellyfish. It gives this message:
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
./eagle: symbol lookup error: /mnt/old-home/austin/projects/cad/eagle/eagle-9.6.2/plugins/bearer/libqconnmanbearer.so: undefined symbol: _ZdlPvm, version Qt_5
Tried:
LIBGL_ALWAYS_SOFTWARE=1 QT_XCB_GL_INTEGRATION=xcb_egl ./eagle
with the same result.
echo $LD_LIBRARY_PATH
$ :/usr/local/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu/dri
Grateful for suggestions on where to look next.
Solved by austin_green. Go to Solution.
See if you can get past the error by removing the plugin.
Not sure I understand you - which plugin, and how do I remove it?
