Installation & Licensing
Ubuntu 22.04 "Cannot create platform OpenGL context"
3 REPLIES 3
austin_green
2151 Views, 3 Replies
austin_green
Cannot get Eagle to run on Ubuntu 22.04 LTS Jammy Jellyfish. It gives this message:
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
./eagle: symbol lookup error: /mnt/old-home/austin/projects/cad/eagle/eagle-9.6.2/plugins/bearer/libqconnmanbearer.so: undefined symbol: _ZdlPvm, version Qt_5
Tried:
LIBGL_ALWAYS_SOFTWARE=1 QT_XCB_GL_INTEGRATION=xcb_egl ./eagle
with the same result.
echo $LD_LIBRARY_PATH
$ :/usr/local/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu/dri
Grateful for suggestions on where to look next.
Tried:
3 REPLIES 3
TravisNave
in reply to: austin_green
TravisNave
See if you can get past the error by removing the plugin.
Autodesk Forums:
Autodesk Forums:
austin_green
in reply to: TravisNave
austin_green
@TravisNave:
Not sure I understand you - which plugin, and how do I remove it?
@TravisNave:
austin_green
austin_green
After a lot of searching I found this site, which recommends deleting all files matching
lib/libxcb*
which I did, and Eagle then worked properly.
No idea what those libraries are for, but Eagle seems to work better without them!
lib/libxcb*
Administrator Productivity
