Issue: When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install.
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1: In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website. For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15924324&linkID=9240857
Solution #2: In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer. Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel. You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7: Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall. This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again. If you run into additional failures on prerequisites, repeat the process. You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
Note: When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
Solved by dzanta. Go to Solution.
Solved by jessica.t. Go to Solution.
Solved by asburyj. Go to Solution.
Solved by TravisNave. Go to Solution.
Yep. If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
2016/5/21:10:44:26 Lounas LOUNAS-PC === Setup started on LOUNAS-PC by Lounas === 2016/5/21:10:44:26 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:10:44:26 Lounas LOUNAS-PC Current Directory C:\Autodesk\Autodesk_Revit_2015_French_Win_64bit_R2_wi_fr-FR 2016/5/21:10:44:26 Lounas LOUNAS-PC Launch 2016/5/21:10:44:26 Lounas LOUNAS-PC CommandLine /PK 829G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_French_Win_64bit_R2_wi_fr-FR_... 2016/5/21:10:44:26 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:10:44:26 Lounas LOUNAS-PC Current Directory C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp 2016/5/21:10:44:32 Lounas LOUNAS-PC === Setup ended === 2016/5/21:10:44:29 Lounas LOUNAS-PC === Setup started on LOUNAS-PC by Lounas === 2016/5/21:10:44:29 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:10:44:29 Lounas LOUNAS-PC Current Directory C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp 2016/5/21:10:44:29 Lounas LOUNAS-PC Launch 2016/5/21:10:44:31 Lounas LOUNAS-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/SETUP_x64.... 2016/5/21:10:44:32 Lounas LOUNAS-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp\Setup\RevitSetup.dll 2016/5/21:10:44:32 Lounas LOUNAS-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2016/5/21:10:44:33 Lounas LOUNAS-PC PageOpen LaunchDialog 2016/5/21:10:44:49 Lounas LOUNAS-PC Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp\Setup\RevitSetup.dll 2016/5/21:10:44:49 Lounas LOUNAS-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=La désélection de l'installation du contenu a une incidence sur les paramètres critiques dans Autodesk® Revit® 2015. URLTitle= URLLink= 2016/5/21:10:46:05 Lounas LOUNAS-PC PageOpen LicenseDialog 2016/5/21:10:46:05 Lounas LOUNAS-PC PageOpen ProductInfoDialog 2016/5/21:10:46:05 Lounas LOUNAS-PC PageOpen ProductSelectionDialog2 2016/5/21:10:48:59 Lounas LOUNAS-PC PageOpen FullProgressDialog 2016/5/21:10:48:59 Lounas LOUNAS-PC Download Skipped VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:10:48:59 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Lounas\AppData\Local\Temp\vcredist_x86_2005.log"" " 2016/5/21:10:49:08 Lounas LOUNAS-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2016/5/21:10:49:08 Lounas LOUNAS-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:10:49:08 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2016/5/21:10:49:48 Lounas LOUNAS-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/21:10:49:48 Lounas LOUNAS-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:10:49:48 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2016/5/21:10:51:07 Lounas LOUNAS-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/21:10:51:07 Lounas LOUNAS-PC Download Skipped VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:10:51:07 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Lounas\AppData\Local\Temp\vcredist_x86_2005.log"" " 2016/5/21:10:52:15 Lounas LOUNAS-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2016/5/21:10:52:16 Lounas LOUNAS-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:10:52:42 Lounas LOUNAS-PC Install FaroSDK Succeeded 2016/5/21:10:52:42 Lounas LOUNAS-PC Download Skipped RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RCL2015_x6... 2016/5/21:10:52:44 Lounas LOUNAS-PC Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:29:20 Lounas LOUNAS-PC Install Autodesk® Revit® Content Libraries 2015 Succeeded 2016/5/21:11:29:20 Lounas LOUNAS-PC Download Skipped RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RVT2015_x6... 2016/5/21:11:29:23 Lounas LOUNAS-PC Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\fr-fr\RVT2015\RVT2015.mst;C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:35:58 Lounas LOUNAS-PC Install Autodesk® Revit® 2015 Succeeded 2016/5/21:11:35:58 Lounas LOUNAS-PC Download Skipped RVT2015_fr-fr http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RVT2015_x6... 2016/5/21:11:35:59 Lounas LOUNAS-PC Installing Module linguistique d'Autodesk® Revit® 2015: TRANSFORMS="C:\Users\Lounas\AppData\Local\Temp\_AIB6A0.tmp\_laE8BF.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:36:21 Lounas LOUNAS-PC Install Module linguistique d'Autodesk® Revit® 2015 Succeeded 2016/5/21:11:36:22 Lounas LOUNAS-PC Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:36:32 Lounas LOUNAS-PC Install Autodesk Workflows 2015 Succeeded 2016/5/21:11:36:33 Lounas LOUNAS-PC Download Skipped CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CM2015.tar... 2016/5/21:11:36:33 Lounas LOUNAS-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:37:13 Lounas LOUNAS-PC Install Autodesk Material Library 2015 Succeeded 2016/5/21:11:37:13 Lounas LOUNAS-PC Download Skipped CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILB2015.... 2016/5/21:11:37:13 Lounas LOUNAS-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:37:41 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded 2016/5/21:11:37:41 Lounas LOUNAS-PC Download Skipped CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILL2015.... 2016/5/21:11:37:41 Lounas LOUNAS-PC Installing Autodesk Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:38:12 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Low Image Library Succeeded 2016/5/21:11:38:12 Lounas LOUNAS-PC Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:11:38:31 Lounas LOUNAS-PC Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2016/5/21:11:38:32 Lounas LOUNAS-PC Download Play CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILM2015.... 2016/5/21:11:46:56 Lounas LOUNAS-PC Download Aborted CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILM2015.... 2016/5/21:11:46:56 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603 2016/5/21:11:47:28 Lounas LOUNAS-PC Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2016/5/21:11:47:47 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 - Low Image Library Succeeded 2016/5/21:11:48:03 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2016/5/21:11:48:32 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 Succeeded 2016/5/21:11:48:36 Lounas LOUNAS-PC Rollback Autodesk Workflows 2015 Succeeded 2016/5/21:11:48:42 Lounas LOUNAS-PC Rollback Module linguistique d'Autodesk® Revit® 2015 Succeeded 2016/5/21:11:50:03 Lounas LOUNAS-PC Rollback Autodesk® Revit® 2015 Succeeded 2016/5/21:11:53:25 Lounas LOUNAS-PC Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2016/5/21:11:53:30 Lounas LOUNAS-PC Rollback FaroSDK Succeeded 2016/5/21:11:53:30 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2016/5/21:11:53:30 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/21:11:53:30 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/21:11:53:30 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/21:11:53:32 Lounas LOUNAS-PC PageOpen InstallCompleteDialog 2016/5/21:11:53:55 Lounas LOUNAS-PC === Setup ended === 2016/5/21:11:56:26 Lounas LOUNAS-PC === Setup started on LOUNAS-PC by Lounas === 2016/5/21:11:56:26 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:11:56:26 Lounas LOUNAS-PC Current Directory C:\Autodesk\Autodesk_Revit_2015_French_Win_64bit_R2_wi_fr-FR 2016/5/21:11:56:26 Lounas LOUNAS-PC Launch 2016/5/21:11:56:26 Lounas LOUNAS-PC CommandLine /PK 829G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_French_Win_64bit_R2_wi_fr-FR_... 2016/5/21:11:56:26 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:11:56:26 Lounas LOUNAS-PC Current Directory C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp 2016/5/21:11:56:37 Lounas LOUNAS-PC === Setup ended === 2016/5/21:11:56:27 Lounas LOUNAS-PC === Setup started on LOUNAS-PC by Lounas === 2016/5/21:11:56:27 Lounas LOUNAS-PC Path_Length: 155 2016/5/21:11:56:27 Lounas LOUNAS-PC Current Directory C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp 2016/5/21:11:56:27 Lounas LOUNAS-PC Launch 2016/5/21:11:56:36 Lounas LOUNAS-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/SETUP_x64.... 2016/5/21:11:56:37 Lounas LOUNAS-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp\Setup\RevitSetup.dll 2016/5/21:11:56:37 Lounas LOUNAS-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2016/5/21:11:56:37 Lounas LOUNAS-PC PageOpen LaunchDialog 2016/5/21:11:56:46 Lounas LOUNAS-PC Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp\Setup\RevitSetup.dll 2016/5/21:11:56:46 Lounas LOUNAS-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=La désélection de l'installation du contenu a une incidence sur les paramètres critiques dans Autodesk® Revit® 2015. URLTitle= URLLink= 2016/5/21:11:57:09 Lounas LOUNAS-PC PageOpen LicenseDialog 2016/5/21:11:57:09 Lounas LOUNAS-PC PageOpen ProductInfoDialog 2016/5/21:11:57:09 Lounas LOUNAS-PC PageOpen ProductSelectionDialog2 2016/5/21:11:57:40 Lounas LOUNAS-PC PageOpen FullProgressDialog 2016/5/21:11:57:41 Lounas LOUNAS-PC Download Skipped VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:11:57:41 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Lounas\AppData\Local\Temp\vcredist_x86_2005.log"" " 2016/5/21:11:57:48 Lounas LOUNAS-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2016/5/21:11:57:48 Lounas LOUNAS-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:11:57:48 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2016/5/21:11:58:35 Lounas LOUNAS-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/21:11:58:36 Lounas LOUNAS-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/VCREDIST20... 2016/5/21:11:58:36 Lounas LOUNAS-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2016/5/21:12:00:22 Lounas LOUNAS-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/21:12:00:24 Lounas LOUNAS-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:01:52 Lounas LOUNAS-PC Install FaroSDK Succeeded 2016/5/21:12:01:52 Lounas LOUNAS-PC Download Skipped RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RCL2015_x6... 2016/5/21:12:01:56 Lounas LOUNAS-PC Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:39:00 Lounas LOUNAS-PC Install Autodesk® Revit® Content Libraries 2015 Succeeded 2016/5/21:12:39:00 Lounas LOUNAS-PC Download Skipped RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RVT2015_x6... 2016/5/21:12:39:04 Lounas LOUNAS-PC Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\fr-fr\RVT2015\RVT2015.mst;C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:45:53 Lounas LOUNAS-PC Install Autodesk® Revit® 2015 Succeeded 2016/5/21:12:45:53 Lounas LOUNAS-PC Download Skipped RVT2015_fr-fr http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/RVT2015_x6... 2016/5/21:12:45:54 Lounas LOUNAS-PC Installing Module linguistique d'Autodesk® Revit® 2015: TRANSFORMS="C:\Users\Lounas\AppData\Local\Temp\_AIA285.tmp\_laEC0B.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:46:19 Lounas LOUNAS-PC Install Module linguistique d'Autodesk® Revit® 2015 Succeeded 2016/5/21:12:46:19 Lounas LOUNAS-PC Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:46:28 Lounas LOUNAS-PC Install Autodesk Workflows 2015 Succeeded 2016/5/21:12:46:28 Lounas LOUNAS-PC Download Skipped CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CM2015.tar... 2016/5/21:12:46:29 Lounas LOUNAS-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:46:54 Lounas LOUNAS-PC Install Autodesk Material Library 2015 Succeeded 2016/5/21:12:46:54 Lounas LOUNAS-PC Download Skipped CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILB2015.... 2016/5/21:12:46:54 Lounas LOUNAS-PC Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:47:11 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Base Image Library Succeeded 2016/5/21:12:47:11 Lounas LOUNAS-PC Download Skipped CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILL2015.... 2016/5/21:12:47:12 Lounas LOUNAS-PC Installing Autodesk Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:47:44 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Low Image Library Succeeded 2016/5/21:12:47:44 Lounas LOUNAS-PC Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/21:12:47:58 Lounas LOUNAS-PC Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2016/5/21:12:47:58 Lounas LOUNAS-PC Download Play CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILM2015.... 2016/5/21:12:57:01 Lounas LOUNAS-PC Download Aborted CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{7905D92A-A0C7-421F-AA4E-62BD9C6FCBCA}/CMILM2015.... 2016/5/21:12:57:01 Lounas LOUNAS-PC Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603 2016/5/21:12:57:31 Lounas LOUNAS-PC Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2016/5/21:12:58:06 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 - Low Image Library Succeeded 2016/5/21:12:58:32 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2016/5/21:12:59:24 Lounas LOUNAS-PC Rollback Autodesk Material Library 2015 Succeeded 2016/5/21:12:59:29 Lounas LOUNAS-PC Rollback Autodesk Workflows 2015 Succeeded 2016/5/21:12:59:47 Lounas LOUNAS-PC Rollback Module linguistique d'Autodesk® Revit® 2015 Succeeded 2016/5/21:13:03:37 Lounas LOUNAS-PC Rollback Autodesk® Revit® 2015 Succeeded 2016/5/21:13:06:12 Lounas LOUNAS-PC Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2016/5/21:13:06:17 Lounas LOUNAS-PC Rollback FaroSDK Succeeded 2016/5/21:13:06:17 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/21:13:06:17 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/21:13:06:17 Lounas LOUNAS-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
WARNING: This is a worldwide public user community and it's important that you do not include/share your serial # in your posting/attachments. I will have the moderator remove your serial # in order to protect your information. For the future please keep that rule in mind.
Your download is failing due to the method you're using.
Click on the “installation” link in my signature and follow the recommended steps that are provided in that posting. Make sure to review all of the acceptable solutions (marked in green) since these steps will change over time.
For example the most recent solution now includes a link to the major 2017 product line making it easier for the end user to download/install the latest version of the software.
If your installation does fail after these recommended steps
• Review this posting: http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-file/m-p/5283115
• If that doesn’t help, attach your installation log file here in a text file format and someone will review it for you. You can also locate your installation log file based on this posting: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Using-log-to-troubleshoot-installation-errors.html
• When attaching your installation log file make sure that any personal information such as your serial # is removed.
Good luck on your installation and hopefully this information will resolve your issue.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks TravisNave,
I had same issues with 3dsmax 2017 and trick with editing setup.ini file worked for me. Before that I tried uninstalling(like You suggested) all Microsoft's redistributables and .net framework 4.5.1, which caused problems, and that didn't work.
As I said, editing that .ini file solved problem.
Thanks a lot!!!
Everybody keeps fixing these install problems by reinstalling Microsoft's redistributables (.net framework 4.5.1 or whatever version ACAD uses). I beleive this will work, but there is an easier way!
I have found a way to get this software to load & this is how to do it:
1) Go to Control panel "Programs"-uninstall a program
2) Go to Microsoft Visual C++ 2010 x86 Redistributable Version 10.0.40219 & pick Then pick Turn Windows features on or off.
3) When the dialog box comes up you will see a folder .NET Framework 4.6 Advance Services. You will see a filled box which means that only part of this feature is turned on.
Clear this box to enable this feature
4) Install Autodesk Design Suite Standard 2012.
5) Reboot when prompted.
6) Install is complete.
Now, change the dialog box back like you found it in step 3. The real problem is that once that the state of Microsoft Net Framework with this feature disabled does not allow HTTP Activation, TCP Activation,MSMQ activation or Named pipe activation & this is why ACAD products abort on previously installed versions.
Also if you look at all the different versions of NET Framework, you will see that after the original program it is distributed for is installed, Microsoft disables all activation protocals. Another thing my ACAD product was doing is trying to activate using every version of Net Framework. All these have a subfolder ".NET Framework 4.6 Advance Services" By being able to enable this feature on Version 10 (supplied with Windows 10 & my Navidia graphic card) I have found that it does not matter which one you temporay enable the activation feature, but without reinstalling Net Framework or doing this fix "ACAD WILL NOT INSTALL ERROR" (1502 ? i THINK)
I NEED HELP, i got the same problem and i did all the think like uninstall the MSV C++ 2012(x64)(x86), UAC disabled and disable real-time anti-virus but it still not working for me i need to use 3d max for my school work can someone help
And i got autoCAD 2016 install will it affect on it?
Thanks.
@Anonymous
Welcome to the community...
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Also when sharing information such as your log file.. Just make sure you remove your serial # before posting. This is a world wide user forum.
Mark Lancaster
@Anonymous
Without seeing your installation log file I don't know what's going on. 1603 errors are generic.. Your installation could be failing on download. So post your installation log file here so we can review. However installation log files sometimes contains your serial # so make sure to remove it before posting.
Mark Lancaster
@Anonymous
So download and install per:
Mark Lancaster
@Anonymous and @Anonymous
Stop putting your crap here. This is a professional site and no one needs you putting this type of stuff here or trying to sell your stuff here.. Take it elsewhere..
Mark Lancaster
I have no idea why you sent me this Email. I'm not trying to sell anything. Maybe you are trying to contact someone else.
@Anonymous
There's a couple of trolls on here posting inappropriate material and I was telling them to take their crap elsewhere.. They keep doing it to other postings as well and some of us are wasting time thinking that someone needs assistance.
So when I replied to those individuals to tell them to stop doing it, everybody who is watching this posting gets my reply.. It wasn't directed to you or anybody else except for those 2 individuals. The moderator has already removed their postings here (and hopefully they got banned)..
Have a great day....
Mark Lancaster
2016/8/25:07:06:58 Katka KATKA-WS === Setup started on KATKA-WS by Katka ===
2016/8/25:07:06:58 Katka KATKA-WS Path_Length: 148
2016/8/25:07:06:58 Katka KATKA-WS Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_de-DE
2016/8/25:07:06:58 Katka KATKA-WS Launch
2016/8/25:07:06:58 Katka KATKA-WS CommandLine /PK 128G1 /SN 900-76227142 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_d..."
2016/8/25:07:06:58 Katka KATKA-WS Current Directory C:\Users\Katka\AppData\Local\Temp\_AI6D08.tmp
2016/8/25:07:07:31 Katka KATKA-WS === Setup ended ===
2016/8/25:07:06:59 Katka KATKA-WS === Setup started on KATKA-WS by Katka ===
2016/8/25:07:06:59 Katka KATKA-WS Path_Length: 148
2016/8/25:07:06:59 Katka KATKA-WS Current Directory C:\Users\Katka\AppData\Local\Temp\_AI6D08.tmp
2016/8/25:07:06:59 Katka KATKA-WS Launch
2016/8/25:07:06:59 Katka KATKA-WS Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2016/8/25:07:07:30 Katka KATKA-WS Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2016/8/25:07:07:30 Katka KATKA-WS PageOpen LaunchDialog
2016/8/25:07:11:05 Katka KATKA-WS PageOpen LicenseDialog
2016/8/25:07:11:05 Katka KATKA-WS PageOpen ProductInfoDialog
2016/8/25:07:11:05 Katka KATKA-WS PageOpen ProductSelectionDialog2
2016/8/25:07:11:10 Katka KATKA-WS PageOpen FullProgressDialog
2016/8/25:07:11:11 Katka KATKA-WS Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2016/8/25:07:11:15 Katka KATKA-WS Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2016/8/25:07:11:15 Katka KATKA-WS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/8/25:07:11:25 Katka KATKA-WS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/25:07:11:26 Katka KATKA-WS Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2016/8/25:07:11:31 Katka KATKA-WS Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2016/8/25:07:11:31 Katka KATKA-WS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/8/25:07:12:42 Katka KATKA-WS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/8/25:07:12:42 Katka KATKA-WS Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2016/8/25:07:12:47 Katka KATKA-WS Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2016/8/25:07:12:47 Katka KATKA-WS Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/25:07:13:56 Katka KATKA-WS Install DirectX® Runtime Succeeded
2016/8/25:07:13:57 Katka KATKA-WS Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2016/8/25:07:14:37 Katka KATKA-WS Download Complete CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2016/8/25:07:14:37 Katka KATKA-WS Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=de-de SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/25:07:15:15 Katka KATKA-WS Install Autodesk® Material Library 2015 Succeeded
2016/8/25:07:15:15 Katka KATKA-WS Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.t...
2016/8/25:07:15:57 Katka KATKA-WS Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.t...
2016/8/25:07:15:57 Katka KATKA-WS Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=de-de SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/25:07:16:29 Katka KATKA-WS Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/8/25:07:16:29 Katka KATKA-WS Download Play CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.t...
2016/8/25:07:24:00 Katka KATKA-WS Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.t...
2016/8/25:07:24:00 Katka KATKA-WS Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/8/25:07:24:02 Katka KATKA-WS Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/8/25:07:24:29 Katka KATKA-WS Rollback Autodesk® Material Library 2015 Succeeded
2016/8/25:07:24:29 Katka KATKA-WS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/8/25:07:24:29 Katka KATKA-WS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/25:07:24:29 Katka KATKA-WS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/25:07:24:29 Katka KATKA-WS PageOpen InstallCompleteDialog
2016/8/25:07:26:22 Katka KATKA-WS === Setup ended ===
2016/8/25:19:23:41 Katka KATKA-WS === Setup started on KATKA-WS by Katka ===
2016/8/25:19:23:41 Katka KATKA-WS Path_Length: 148
2016/8/25:19:23:41 Katka KATKA-WS Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_de-DE
2016/8/25:19:23:41 Katka KATKA-WS Launch
2016/8/25:19:23:41 Katka KATKA-WS CommandLine /URL "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_d..." /skipPI /SN 900-76227142 /PK 128G1 /akamai
2016/8/25:19:23:41 Katka KATKA-WS Current Directory C:\Users\Katka\AppData\Local\Temp\_AIAB8B.tmp
2016/8/25:19:23:59 Katka KATKA-WS === Setup ended ===
2016/8/25:19:23:44 Katka KATKA-WS === Setup started on KATKA-WS by Katka ===
2016/8/25:19:23:44 Katka KATKA-WS Path_Length: 148
2016/8/25:19:23:44 Katka KATKA-WS Current Directory C:\Users\Katka\AppData\Local\Temp\_AIAB8B.tmp
2016/8/25:19:23:44 Katka KATKA-WS Launch
@Anonymous
Your download is failing due to the method you're using...
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
thanks.
i was trying to download from folowing link:
http://www.autodesk.com/education/free-software/3ds-max
as you can see, you don´t have realy another option to download the software.
thank you for your help now everithing works 🙂
