Installation & Licensing
My Windows 10 Computer does not allow installation of AutoCad 2019
5 REPLIES 5
736 Views, 5 Replies
Everytime I try to install the software, the setup initialization window states "You cannot install this product on the current operating system. Please read the system requirements for details."
I have an x64bit Windows and more than enough space.
I don't know what to do
Labels (1)
5 REPLIES 5
cadffm
Download the install package for x64 Windows version of AutoCAD, try it again.
(I am missing the information about the source file or link you are trying to install, and the built version of your windows)
Sebastian
ennujozlagam
you can try to refer to this LINK and see if helps. thanks
Hotter_R
Hi @Anonymous ,
can you pleas give us a little bit more information about your computer (hardware).
If you run msinfo32.exe in the search bar, you get information about CPU and so on.
Rainer Hotter
Technical Support Specialist - Installation & Licensing
mdavis22569
in reply to: cadffm
TYPE WINVER in the TYPE HERE TO SEARCH.
You'll get a popup like this:
winver.PNG'
Make sure it's at least 1603 or higher..... 1909 would be best and fully updated
Mike Davis
Thank you to all your answers.
I went through every solution and they all didn't work so I went to get my system checked. My system was running on a very old version of windows 10 so I updated it and it worked perfectly.
Administrator Productivity
