Installation & Licensing
Some Products Fail to Install, Result 1603
280 REPLIES 280
Message 1 of 281
TravisNave
813855 Views, 280 Replies
Issue:  When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1:  In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website.  For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15924324&linkID=9240857
Solution #2:  In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer.  Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel.  You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7:  Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall.  This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again.  If you run into additional failures on prerequisites, repeat the process.  You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
http://upandready.typepad.com/up_and_ready/2011/09/autodesk-suites-product-design-suite-will-not-ins...
Note:  When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
Autodesk Forums:
Tags (2)
280 REPLIES 280
Message 41 of 281
@michael_cadaxis wrote:
Link below worked for me and none from other suggestions.
vhttp://synergiscadblog.com/tag/error-1603/
Darren Green posted the ORCA solution here.
http://forums.autodesk.com/t5/Installation-Licensing/DirectX-Runtime-Failed-Failure-is-ignored-Resul...
Autodesk Forums:
Message 42 of 281
in reply to: TravisNave
Im sorry but I dont know how to create a new thread so I reply. I am having an error 1603 but I dont know how to fix it. Here is the installation log:
2014/2/5:19:59:43 Toshiba User TOSHIBAUSER-PC === Setup started on TOSHIBAUSER-PC by Toshiba User ===
2014/2/5:19:59:43 Toshiba User TOSHIBAUSER-PC Path_Length: 151
2014/2/5:19:59:43 Toshiba User TOSHIBAUSER-PC Current Directory C:\Users\TOSHIB~1\AppData\Local\Temp\_AIEA4B.tmp
2014/2/5:19:59:43 Toshiba User TOSHIBAUSER-PC Launch
2014/2/5:19:59:45 Toshiba User TOSHIBAUSER-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/2/5:20:01:53 Toshiba User TOSHIBAUSER-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/2/5:20:01:54 Toshiba User TOSHIBAUSER-PC PageOpen LaunchDialog
2014/2/5:20:02:02 Toshiba User TOSHIBAUSER-PC PageOpen LicenseDialog
2014/2/5:20:02:04 Toshiba User TOSHIBAUSER-PC PageOpen ProductInfoDialog
2014/2/5:20:02:04 Toshiba User TOSHIBAUSER-PC PageOpen ProductSelectionDialog2
2014/2/5:20:02:19 Toshiba User TOSHIBAUSER-PC PageOpen FullProgressDialog
2014/2/5:20:02:21 Toshiba User TOSHIBAUSER-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/2/5:20:02:25 Toshiba User TOSHIBAUSER-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/2/5:20:02:25 Toshiba User TOSHIBAUSER-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TOSHIB~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/5:20:02:48 Toshiba User TOSHIBAUSER-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
I am having the error that says: Installation Complete. Some products failed to install.
PLEASE HELP!!!!
Message 43 of 281
TravisNave
It is failing here:
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Autodesk Forums:
Message 44 of 281
Hmmm.... I'm having similar trouble with installation of Recap in Building Suite 2014, however is doesn't show an link to the log file. I've retrieved it myself and is says the following. It seems there is anissue with the Language Pack.... I can't find a topic on this forum about this issue. Please help.
(Ok, this is probably suppost to be a new thread... I'm sorry, don't know how to, but I'm looking into it)
2014/3/10:16:50:11 tijmen WAM-USR-HP Installing Autodesk® ReCap: TRANSFORMS="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\x64\en-us\RC2014\AutodeskReCap.mst;C:\Users\tijmen\AppData\Local\Temp\_AI3E1A.tmp\x64\RC2014\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:50:54 tijmen WAM-USR-HP Install Autodesk® ReCap Succeeded
2014/3/10:16:50:54 tijmen WAM-USR-HP Installing Autodesk® ReCap Language Pack: TRANSFORMS="C:\Users\tijmen\AppData\Local\Temp\_AI3E1A.tmp\_la9BEB.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Premium_2014_English_Win_32_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:50:55 tijmen WAM-USR-HP Install Autodesk® ReCap Language Pack Failed Installation aborted, Result=1638
2014/3/10:16:51:05 tijmen WAM-USR-HP Rollback Autodesk® ReCap Succeeded
Message 45 of 281
david.lau
Message 46 of 281
2014/3/25:19:58:26 Ehsan_Barwary BARWARY === Setup started on BARWARY by Ehsan_Barwary ===
2014/3/25:19:58:26 Ehsan_Barwary BARWARY Path_Length: 157
2014/3/25:19:58:26 Ehsan_Barwary BARWARY Current Directory F:
2014/3/25:19:58:26 Ehsan_Barwary BARWARY Launch
2014/3/25:19:58:26 Ehsan_Barwary BARWARY CommandLine
2014/3/25:19:58:26 Ehsan_Barwary BARWARY Current Directory C:\Users\EHSAN_~1\AppData\Local\Temp\_AI490.tmp
2014/3/25:19:59:38 Ehsan_Barwary BARWARY === Setup ended ===
2014/3/25:19:58:56 Ehsan_Barwary BARWARY === Setup started on BARWARY by Ehsan_Barwary ===
2014/3/25:19:58:56 Ehsan_Barwary BARWARY Path_Length: 157
2014/3/25:19:58:56 Ehsan_Barwary BARWARY Current Directory C:\Users\EHSAN_~1\AppData\Local\Temp\_AI490.tmp
2014/3/25:19:58:56 Ehsan_Barwary BARWARY Launch
2014/3/25:19:59:06 Ehsan_Barwary BARWARY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\EHSAN_~1\AppData\Local\Temp\_AI490.tmp\Setup\AcSetup.dll
2014/3/25:19:59:06 Ehsan_Barwary BARWARY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/25:19:59:39 Ehsan_Barwary BARWARY PageOpen LaunchDialog
2014/3/25:19:59:54 Ehsan_Barwary BARWARY PageOpen LicenseDialog
2014/3/25:19:59:56 Ehsan_Barwary BARWARY PageOpen ProductInfoDialog
2014/3/25:20:00:08 Ehsan_Barwary BARWARY PageOpen ProductSelectionDialog2
2014/3/25:20:00:11 Ehsan_Barwary BARWARY PageOpen FullProgressDialog
2014/3/25:20:00:11 Ehsan_Barwary BARWARY Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "F:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/3/25:20:00:26 Ehsan_Barwary BARWARY Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Message 47 of 281
david.lau
For issue above, you can try to hack out the setup.ini file to install install the Microsoft Visual C++ 2008 SP1.
Look for VCREDIST2008SP1X86;VCREDIST2008SP1X64 in the setup.ini file and remove the entries for it.
http://upandready.typepad.com/up_and_ready/2013/05/autocad-2012-net-45-hacking-the-setupini.html
After the install, you can run a Windows update and it should update the Microsoft component.
David Lau
Message 48 of 281
I have this problem too? please, help me. I turned off the antivirus, UAC,firewall, and have this problem:
"2014/3/27:22:06:14 Vitalya VITALYA-PC Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603
2014/3/27:22:06:19 Vitalya VITALYA-PC Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/27:22:06:26 Vitalya VITALYA-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Autodesk® Material Library 2014 Succeeded
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/3/27:22:07:13 Vitalya VITALYA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/3/27:22:07:16 Vitalya VITALYA-PC PageOpen InstallCompleteDialog" Than i'm uninstall all .NET Framework, and Microsoft Visual C++, and start setup again. That not fix my problem...Than i tried modify setup.ini: i'm deleted "dotnet", "vcredist", "directX" but it still don't work.
Message 49 of 281
Message 50 of 281
TravisNave
@Anonymous that is because your installation is not failing on a prereq, but the actual program installation.  I would download the product fresh from the virtual assistant and then install it without adding any service updates during installation.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-re-download-software.html
Try again and let me know.
Autodesk Forums:
Message 51 of 281
Im having the same problem with autocad 2014... How do i know which program to uninstall in my control panel? The Autodesk software came with 9 different parts that are all in my control panel and i don't know which to uninstall? What do i do after i uninstall the program? Thanks
Message 52 of 281
TravisNave
Jake, there is no way to know without your installation log file.
Autodesk Forums:
Message 53 of 281
This is a picture of my installation log file...Which one do i delete?
Message 54 of 281
TravisNave
That doesn't help me.  I need your installation log file that is available after your failed install.  You can click it from the failure screen or grab it from your %TEMP% folder.
Autodesk Forums:
Message 55 of 281
You said that you needed my installation log file that is available after my failed install. Autocad installed onto my laptop and i can use it when i select the "try" option when i open the program and it alerts me that i have 28 days left to activate. When i select the "activate" option it tells me that i have no internet connection. So the program works fine when i select the try option but it won't let me activate it and have the program permanently.
Message 56 of 281
jessica.t
Hi @jakeleep465,
Perhaps this work instruction on how locate your installation log files will help. Be sure to let us know!
Jessica Thrasher
Message 57 of 281
TravisNave
You can use the online method to activate your license here:
http://knowledge.autodesk.com/installation-and-licensing
Or you can can call Autodesk Product Registration and Authorization:
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
You will need to provide your serial number and the request code.
That should get you up and running.
Autodesk Forums:
Message 58 of 281
I tried to follow the steps for offline activation  but after i select "Request an activation code using an offline method" it brings me to the next window but there is no option to select country/individual or what country the product will  be used. The only options are "back and close"
Message 59 of 281
philip.s
@Anonymous are you able to get to the screen displaying your request code? If so can you send it to me in a Private Message along with your serial number?
Message 60 of 281
Hi Travis or Philip S, if you could help me out too I would really appreciate it! Soooooo much! I am trying to install Autocad 2014, I have already remove ALL of the Microsoft Visual C+++ and re-start my computer a couple of times but it still does not work.. The two log files are as follows (I need this asap for studies so hopefully you can help me out):
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD === Setup started on ANDRIANACOBBOLD by andriana.cobbold ===
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD Path_Length: 155
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD Launch
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-21436416 /PK 001F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/5/31:20:50:53 andriana.cobbold ANDRIANACOBBOLD Current Directory C:\Users\ANDRIA~1.COB\AppData\Local\Temp\_AIBAF5.tmp
2014/5/31:20:51:15 andriana.cobbold ANDRIANACOBBOLD === Setup ended ===
2014/5/31:20:51:07 andriana.cobbold ANDRIANACOBBOLD === Setup started on ANDRIANACOBBOLD by andriana.cobbold ===
2014/5/31:20:51:07 andriana.cobbold ANDRIANACOBBOLD Path_Length: 155
2014/5/31:20:51:07 andriana.cobbold ANDRIANACOBBOLD Current Directory C:\Users\ANDRIA~1.COB\AppData\Local\Temp\_AIBAF5.tmp
2014/5/31:20:51:07 andriana.cobbold ANDRIANACOBBOLD Launch
2014/5/31:20:51:11 andriana.cobbold ANDRIANACOBBOLD Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/5/31:20:51:14 andriana.cobbold ANDRIANACOBBOLD Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ANDRIA~1.COB\AppData\Local\Temp\_AIBAF5.tmp\Setup\AcSetup.dll
2014/5/31:20:51:14 andriana.cobbold ANDRIANACOBBOLD Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/31:20:51:16 andriana.cobbold ANDRIANACOBBOLD PageOpen LaunchDialog
2014/5/31:20:51:59 andriana.cobbold ANDRIANACOBBOLD PageOpen LicenseDialog
2014/5/31:20:51:59 andriana.cobbold ANDRIANACOBBOLD PageOpen ProductInfoDialog
2014/5/31:20:51:59 andriana.cobbold ANDRIANACOBBOLD PageOpen ProductSelectionDialog2
2014/5/31:20:54:31 andriana.cobbold ANDRIANACOBBOLD PageOpen FullProgressDialog
2014/5/31:20:54:32 andriana.cobbold ANDRIANACOBBOLD Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:54:48 andriana.cobbold ANDRIANACOBBOLD Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:54:48 andriana.cobbold ANDRIANACOBBOLD Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/5/31:20:54:57 andriana.cobbold ANDRIANACOBBOLD Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/31:20:54:59 andriana.cobbold ANDRIANACOBBOLD Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:55:08 andriana.cobbold ANDRIANACOBBOLD Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:55:08 andriana.cobbold ANDRIANACOBBOLD Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/31:20:55:21 andriana.cobbold ANDRIANACOBBOLD Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/5/31:20:55:22 andriana.cobbold ANDRIANACOBBOLD Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:55:57 andriana.cobbold ANDRIANACOBBOLD Download Error VCREDIST2010SP1X86 <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:55:57 andriana.cobbold ANDRIANACOBBOLD Download Aborted VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/VCREDIST...
2014/5/31:20:55:58 andriana.cobbold ANDRIANACOBBOLD Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
Second one:
Administrator Productivity
