Installation & Licensing
Network Failure Error
3 REPLIES 3
4241 Views, 3 Replies
Hi guys,
I am a student and while trying to update my autocad student licence, I am coming up with a "Network failure" error?
Having already seen some answers herein, I tried to install the software by just clicking on the file that I have stored in my PC, and not directly from the net, but this solution didn't worked for me.
Thereby, I would really appreciated it whether anyone can provide me with another solution.
Thank you in advance for your valuable time and cooperation.
I am looking forward for your response.
Very best regards,
Vasilis Kamperidis
3 REPLIES 3
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hi Kudos,
Thank you for your help; it is really appreciated. I applied what you suggested, and the installation procedure went ok. However, I am now confronting a different problem; I cannot activate the product. I don't know why. I am applying the username and the password, derived according to the suggested procedure, but with no result.
Vasilis
TravisNave
Might start here, since we cannot do much about Edu licenses:
http://www.autodesk.com/education/support/edu-contact-us-form
Autodesk Forums:
Administrator Productivity
