Installation & Licensing
Maya 2016 Installation Error 1603
6 REPLIES 6
1158 Views, 6 Replies
I'm trying to install Maya 2016 on my Windows 10 pc and am getting the error message "Installation complete. Some products failed to install".
The products that are failing to install are:
  • Maya 2016
  • DirectConnect 2016
  • Autodesk Application Manager
In the error logs I get this error multiple times for both Maya and DirectConnect:
Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Joe\AppData\Local\Temp;c:\ffmpeg\bin\vcredist_x86_2005.log"" "
2016/8/29:17:46:14 Joe LAPTOP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
I uninstalled all versions of Visual C++ 2005 on my computer and the installation still does not work.
I then tried AIDA, the Autodesk Installation Diagnosis Assistant, to see if it could find anything and it too ran into an error when it tried to run:
Next, I emptied my %temp% folder, turned off my uac, and used the Maya 2016 download from the Virtual Agent. My installation still failed.
Here is the error log for Maya 2016:
2016/8/29:17:44:50 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:17:44:50 Joe LAPTOP Path_Length: 153
2016/8/29:17:44:50 Joe LAPTOP Current Directory C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm
2016/8/29:17:44:50 Joe LAPTOP Launch
2016/8/29:17:44:50 Joe LAPTOP CommandLine
2016/8/29:17:44:50 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI5C47.tmp
2016/8/29:17:44:52 Joe LAPTOP === Setup ended ===
2016/8/29:17:44:51 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:17:44:51 Joe LAPTOP Path_Length: 153
2016/8/29:17:44:51 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI5C47.tmp
2016/8/29:17:44:51 Joe LAPTOP Launch
2016/8/29:17:44:52 Joe LAPTOP PageOpen LaunchDialog
2016/8/29:17:44:55 Joe LAPTOP PageOpen LicenseDialog
2016/8/29:17:45:38 Joe LAPTOP PageOpen ProductInfoDialog
2016/8/29:17:46:11 Joe LAPTOP PageOpen ProductSelectionDialog2
2016/8/29:17:46:13 Joe LAPTOP PageOpen FullProgressDialog
2016/8/29:17:46:13 Joe LAPTOP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Joe\AppData\Local\Temp;c:\ffmpeg\bin\vcredist_x86_2005.log"" "
2016/8/29:17:46:16 Joe LAPTOP PageOpen InstallCompleteDialog
2016/8/29:17:46:23 Joe LAPTOP === Setup ended ===
2016/8/29:18:04:43 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:18:04:43 Joe LAPTOP Path_Length: 153
2016/8/29:18:04:43 Joe LAPTOP Current Directory C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm
2016/8/29:18:04:43 Joe LAPTOP Launch
2016/8/29:18:04:43 Joe LAPTOP CommandLine
2016/8/29:18:04:43 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI9253.tmp
2016/8/29:18:05:01 Joe LAPTOP === Setup ended ===
2016/8/29:18:04:49 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:18:04:49 Joe LAPTOP Path_Length: 153
2016/8/29:18:04:49 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI9253.tmp
2016/8/29:18:04:49 Joe LAPTOP Launch
2016/8/29:18:05:02 Joe LAPTOP PageOpen LaunchDialog
2016/8/29:18:05:44 Joe LAPTOP PageOpen LicenseDialog
2016/8/29:18:05:46 Joe LAPTOP PageOpen ProductInfoDialog
2016/8/29:18:06:06 Joe LAPTOP PageOpen ProductSelectionDialog2
2016/8/29:18:06:07 Joe LAPTOP PageOpen FullProgressDialog
2016/8/29:18:06:07 Joe LAPTOP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Joe\AppData\Local\Temp;c:\ffmpeg\bin\vcredist_x86_2005.log"" "
2016/8/29:18:06:08 Joe LAPTOP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/8/29:18:06:08 Joe LAPTOP PageOpen InstallCompleteDialog
2016/8/29:18:18:39 Joe LAPTOP === Setup ended ===
2016/8/29:19:04:23 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:19:04:23 Joe LAPTOP Path_Length: 153
2016/8/29:19:04:23 Joe LAPTOP Current Directory C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm
2016/8/29:19:04:23 Joe LAPTOP Launch
2016/8/29:19:04:23 Joe LAPTOP CommandLine
2016/8/29:19:04:23 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI3236.tmp
2016/8/29:19:04:27 Joe LAPTOP === Setup ended ===
2016/8/29:19:04:24 Joe LAPTOP === Setup started on LAPTOP by Joe ===
2016/8/29:19:04:24 Joe LAPTOP Path_Length: 153
2016/8/29:19:04:24 Joe LAPTOP Current Directory C:\Users\Joe\AppData\Local\Temp\_AI3236.tmp
2016/8/29:19:04:24 Joe LAPTOP Launch
2016/8/29:19:04:26 Joe LAPTOP PageOpen LaunchDialog
2016/8/29:19:04:32 Joe LAPTOP PageOpen LicenseDialog
2016/8/29:19:04:34 Joe LAPTOP PageOpen ProductInfoDialog
2016/8/29:19:04:56 Joe LAPTOP PageOpen ProductSelectionDialog2
2016/8/29:19:05:04 Joe LAPTOP PageOpen FullProgressDialog
2016/8/29:19:05:04 Joe LAPTOP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2016_EN_JP_ZH_Windows_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Joe\AppData\Local\Temp;c:\ffmpeg\bin\vcredist_x86_2005.log"" "
2016/8/29:19:05:05 Joe LAPTOP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
And here is the error log for DirectConnect 2016:
Would appreciate some suggestions on what to do from here.
6 REPLIES 6
Otto
Hello jrapier and welcome to the Autodesk community!
It looks like you’re seeing Error 1603. Error 1603 is a generic error generated by the Microsoft Windows Installer (MSI) when a problem occurred during the installation of your Autodesk product. The following article(s) should help you resolve the problem:
Error 1603 during installation of Autodesk software
Errors during AutoCAD software installation
Here is some general information about installation, licensing and downloading Autodesk software:
AutoCAD 2012 installation fails on machine with NET 4.5
Previous Versions of Autodesk Software
Installation, Activation and Licensing
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community...
THis is a known issue please see this article.  Then try your install again.
 The message you got using the AIDA interface..  Delete as many files in your user's temp folder which is normally located here C:\users\<username>\appdata\local\temp.   Appdata is a hidden folder so you may need to adjust your viewing settings.
Mark Lancaster
in reply to: Mark.Lancaster
Hey Mark,
Thanks for the reply. I have already tried the solutions listed in that article, they do not work for me.
As you can see in this screenshot I have uninstalled the conflicting version of c++ 2005 listed in my error log:
And I have also emptied my temp folder as you can see in this screenshot:
TravisNave
Try changing the location of your %TEMP% folder to C:\Temp.  It could be a permissions issue.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
This allowed me to find a solution! In the process of changing the location of my temp folder I found I had created a temp folder for the ffmpeg program. Once I deleted this folder the script stopped referencing that folder and used the temp folder in appData like it was supposed to. Now I have a successful installation. Thanks guys for your help!
It worked! Thanks a million!! Smiley Very Happy
Administrator Productivity
