Hi all,
what is the solution for this problem ?
You have a broken ProductInformation.pit file located in C:\ProgramData\Adlm\ to resolve the issue you have the following options:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
So what is the solution of this problem when happened?
Have you activated or can you try activating? Or is this a network seat / Desktop Subscription?
The above suggestion didn't help. Also, the path specified is wrong.
The proper path is C:\ProgramData\Autodesk\AdLM
I've found this problem to be specific to a specific user profile when it happens. It can be tested by logging to another local Windows profile and attempting to launch Revit 2016.
When I've encountered it, I've had to remove and recreate the user's Windows profile in order to get it to work. I've tried copying all Revit settings files from another working profile to no avail.
Since there no official solution from Autodesk for this, we'll have to assume this is the fix for some of us, and just hope it doesn't become a recurring problem on our hundreds of Windows machines.
We're using Flexnet licensing. Approximately 250 workstations.
I just had this problem on a pc and it was not profile related but rather machine specific. I was able to resolve by finding a pc with the same applications installed. In this case AutoCAD 2016 and 2017 and Revit 2015, 2016, and 2017 and copied the C:\ProgramData\Autodesk\AdLM\ProductInformation.pit file from the pc that worked to the broken pc. This worked in my case but it appears there are different scenarios with different machines. Just an option you can try.
