I super excited when I logged back on to the Autodesk website to download 3ds Max for my new computer, when I saw that 3ds Max 2017 had been released. I had expected to spent mabye quater of an hour installing it, yet hear I am 3 days later with no success.
After looking through the logs and finding almost meaningless errors and trying every troubleshooting step I could think of including: reebooting, installing as many components as possible separatly, searching through the downloaded temp files and running and running a 3ds Max msi file which ended up kinda working as in it installed but didn't work and it was impossible to unistall (which resulted in be having to do a system restore).
After a lot more experimentation, I feel like I can safely conclude that 3ds Max 2017 is not ready for release. I mean two of the links on the installer go to 404 pages and the free trial download button on the website doesn't do anything. This is some really half baked stuff going on here and I was wondering if this was normal and if I could fix this.
Solved by jeffrey.sin. Go to Solution.
The problem I'm having is not in uninstalling the product but in installing it. Also the virtual agent doesn't have the downloads for 3ds Max 2017.
Hi @Space928,
Welcome to the Community.
What exact error are you getting during download or installation? Can you try using the links below to download the installer instead? Ensure that both files are saved onto the same folder.
Autodesk 3ds Max 2017:
Let us know how it goes. Thanks.
If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
Here's an installation log to help Autodesk fix the bugs in the installer:
2016/5/14:20:59:17 Thoma THOMASDESKTOP-P === Setup started on THOMASDESKTOP-P by Thoma === 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P Launch 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P CommandLine /PK 128I1 /SN 900-57968641 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?dummy=0" 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:20:59:17 Thoma THOMASDESKTOP-P Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI50DD.tmp 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P === Setup ended === 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P === Setup started on THOMASDESKTOP-P by Thoma === 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI50DD.tmp 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P Launch 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2 2016/5/14:20:59:18 Thoma THOMASDESKTOP-P PageOpen LaunchDialog 2016/5/14:21:01:50 Thoma THOMASDESKTOP-P PageOpen LicenseDialog 2016/5/14:21:01:50 Thoma THOMASDESKTOP-P PageOpen ProductSelectionDialog2 2016/5/14:21:02:07 Thoma THOMASDESKTOP-P PageOpen LicenseDialog 2016/5/14:21:02:07 Thoma THOMASDESKTOP-P PageOpen LaunchDialog 2016/5/14:21:02:46 Thoma THOMASDESKTOP-P === Setup ended === 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P === Setup started on THOMASDESKTOP-P by Thoma === 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P Launch 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P CommandLine /PK 128I1 /SN 900-57968641 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?dummy=0" 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:21:08:05 Thoma THOMASDESKTOP-P Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P === Setup ended === 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P === Setup started on THOMASDESKTOP-P by Thoma === 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P Path_Length: 157 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P Launch 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2 2016/5/14:21:08:06 Thoma THOMASDESKTOP-P PageOpen LaunchDialog 2016/5/14:21:08:10 Thoma THOMASDESKTOP-P PageOpen LicenseDialog 2016/5/14:21:08:10 Thoma THOMASDESKTOP-P PageOpen ProductInfoDialog 2016/5/14:21:08:10 Thoma THOMASDESKTOP-P PageOpen ProductSelectionDialog2 2016/5/14:21:08:37 Thoma THOMASDESKTOP-P PageOpen FullProgressDialog 2016/5/14:21:08:37 Thoma THOMASDESKTOP-P Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2 2016/5/14:21:08:37 Thoma THOMASDESKTOP-P Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2 2016/5/14:21:08:37 Thoma THOMASDESKTOP-P Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X86.tar.lzma2 2016/5/14:21:08:37 Thoma THOMASDESKTOP-P Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X64.tar.lzma2 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Download Skipped VCREDIST2013X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X86.tar.lzma2 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Thoma\AppData\Local\Temp\vcredist_x86_2013.log 2016/5/14:21:08:38 Thoma THOMASDESKTOP-P Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/5/14:21:08:39 Thoma THOMASDESKTOP-P Download Skipped VCREDIST2013X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X64.tar.lzma2 2016/5/14:21:08:39 Thoma THOMASDESKTOP-P Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Thoma\AppData\Local\Temp\vcredist_x64_2013.log 2016/5/14:21:08:39 Thoma THOMASDESKTOP-P Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/5/14:21:08:39 Thoma THOMASDESKTOP-P Download Skipped CMAIL http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMAIL.tar.lzma2 2016/5/14:21:08:39 Thoma THOMASDESKTOP-P Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/14:21:08:41 Thoma THOMASDESKTOP-P Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/5/14:21:08:42 Thoma THOMASDESKTOP-P Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/5/14:21:08:49 Thoma THOMASDESKTOP-P Install Autodesk Licensing Manager Succeeded 2016/5/14:21:08:49 Thoma THOMASDESKTOP-P Download Play MAX http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2 2016/5/14:21:12:57 Thoma THOMASDESKTOP-P Download Aborted MAX http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2 2016/5/14:21:12:57 Thoma THOMASDESKTOP-P Install Autodesk® 3ds Max® 2017 Failed Download Failed, Installation aborted, Result=1603 2016/5/14:21:13:08 Thoma THOMASDESKTOP-P Rollback Autodesk Licensing Manager Succeeded 2016/5/14:21:13:09 Thoma THOMASDESKTOP-P Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/5/14:21:13:09 Thoma THOMASDESKTOP-P Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/5/14:21:13:09 Thoma THOMASDESKTOP-P Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/5/14:21:13:09 Thoma THOMASDESKTOP-P Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/5/14:21:13:09 Thoma THOMASDESKTOP-P Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Jeffrey,
When I download the files, I get file names of "Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_001_002.sfx.1432150019" and "Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_002_002.sfx.1432150019", but they will not extract. I tried double-clicking and using 7-zip. Niether method works.
What else can be done?
Mike
I'm having the exact same issue. Instalation halts at part 5 of 15 (3d studio max 2017) at about 80% quoting the following error: "There is a problem with this Windows Installar Package. A program run as part of setup did not finish as expected."
This occurs regardless of using the web installer or the two redistributable packages downloaded from this thread. Really frustrating. Here is the log:
2016/6/4:15:04:58 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:04:58 hal0 THE_RIG Path_Length: 157 2016/6/4:15:04:58 hal0 THE_RIG Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US 2016/6/4:15:04:58 hal0 THE_RIG Launch 2016/6/4:15:04:58 hal0 THE_RIG CommandLine /URL "http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?authparam=b91ba1b191a933c9c10b81c98913132b812b1b811b991b3389b98913a1c933b9&SESSION_ID=a1b3A000009BGbkQAG" /skipPI /Trial /akamai 2016/6/4:15:04:58 hal0 THE_RIG Path_Length: 157 2016/6/4:15:04:58 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp 2016/6/4:15:04:59 hal0 THE_RIG === Setup ended === 2016/6/4:15:04:58 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:04:58 hal0 THE_RIG Path_Length: 157 2016/6/4:15:04:58 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp 2016/6/4:15:04:58 hal0 THE_RIG Launch 2016/6/4:15:04:58 hal0 THE_RIG Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=1467630321_9bcc00207dedfd81b76a103387415bf0 2016/6/4:15:04:59 hal0 THE_RIG Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=1467630322_64b41703c6815776d05843ae03ea8754 2016/6/4:15:04:59 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:05:03 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:05:10 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:05:10 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:05:29 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:05:29 hal0 THE_RIG Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=1467630631_3195fa5ba4fdb6bf68f4c204aa62b526 2016/6/4:15:05:30 hal0 THE_RIG Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X86.tar.lzma2?authparam=1467630631_5bd964a8db3538c51e2b5a9e005f59d5 2016/6/4:15:05:30 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/6/4:15:05:33 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/6/4:15:05:34 hal0 THE_RIG Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X64.tar.lzma2?authparam=1467630636_c0bcd7e76b4a98d279892e7c1c24fe13 2016/6/4:15:05:34 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/6/4:15:05:37 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/6/4:15:05:37 hal0 THE_RIG Download Skipped VCREDIST2013X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X86.tar.lzma2?authparam=1467630641_f3d71d18f569250bef9d7501c47b77cf 2016/6/4:15:05:37 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log 2016/6/4:15:05:40 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/6/4:15:05:40 hal0 THE_RIG Download Skipped VCREDIST2013X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X64.tar.lzma2?authparam=1467630646_94e19baa96305447c80cdf621d239ba6 2016/6/4:15:05:40 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log 2016/6/4:15:05:45 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/6/4:15:05:45 hal0 THE_RIG Download Skipped CM http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar.lzma2?authparam=1467630651_c25f1b352545476c9b32116fb2885ebf 2016/6/4:15:05:45 hal0 THE_RIG Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:05:51 hal0 THE_RIG Install Autodesk® Material Library 2017 Succeeded 2016/6/4:15:05:51 hal0 THE_RIG Download Skipped CMILB http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB.tar.lzma2?authparam=1467630701_4be5f0df90bdebf3c685f2caf61e90a0 2016/6/4:15:05:51 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:05:55 hal0 THE_RIG Install Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:05:55 hal0 THE_RIG Download Skipped CMILM http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM.tar.lzma2?authparam=1467630717_ed8a0ca237bb025d59b21d791176067f 2016/6/4:15:05:55 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:06:02 hal0 THE_RIG Install Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:06:02 hal0 THE_RIG Download Skipped CMAIL http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMAIL.tar.lzma2?authparam=1467630835_689f6527f4a3249ba8d1e2cde51b0bd4 2016/6/4:15:06:02 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:06:04 hal0 THE_RIG Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:06:04 hal0 THE_RIG Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:06:13 hal0 THE_RIG Install Autodesk Licensing Manager Succeeded 2016/6/4:15:06:13 hal0 THE_RIG Download Skipped MAX http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2?authparam=1467630868_837e3f2a11906bc4ba34033b0cdb0ea4 2016/6/4:15:06:14 hal0 THE_RIG Installing Autodesk® 3ds Max® 2017: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" INSTALLDIR="D:\3DSMax2017\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:09:12 hal0 THE_RIG Install Autodesk® 3ds Max® 2017 Failed Installation aborted, Result=1603 2016/6/4:15:09:23 hal0 THE_RIG Rollback Autodesk Licensing Manager Succeeded 2016/6/4:15:09:23 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:09:26 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:09:29 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:09:34 hal0 THE_RIG Rollback Autodesk® Material Library 2017 Succeeded 2016/6/4:15:09:34 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/6/4:15:09:34 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/6/4:15:09:34 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/6/4:15:09:34 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619 2016/6/4:15:09:34 hal0 THE_RIG PageOpen InstallCompleteDialog 2016/6/4:15:09:36 hal0 THE_RIG === Setup ended === 2016/6/4:15:10:07 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:10:07 hal0 THE_RIG Path_Length: 157 2016/6/4:15:10:07 hal0 THE_RIG Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US 2016/6/4:15:10:07 hal0 THE_RIG Launch 2016/6/4:15:10:07 hal0 THE_RIG CommandLine /akamai /sid a1b3A000009BGbkQAG /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?authparam=b91ba1b191a933c9c10b81c98913132b812b1b811b991b3389b98913a1c933b9&SESSION_ID=a1b3A000009BGbkQAG" 2016/6/4:15:10:07 hal0 THE_RIG Path_Length: 157 2016/6/4:15:10:07 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI51FF.tmp 2016/6/4:15:10:26 hal0 THE_RIG === Setup ended === 2016/6/4:15:10:08 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:10:08 hal0 THE_RIG Path_Length: 157 2016/6/4:15:10:08 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI51FF.tmp 2016/6/4:15:10:08 hal0 THE_RIG Launch 2016/6/4:15:10:08 hal0 THE_RIG Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=%s 2016/6/4:15:10:08 hal0 THE_RIG Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=1467634208_d63710bd98e2a16f267f12fdd826a6b0 2016/6/4:15:10:08 hal0 THE_RIG Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=%s 2016/6/4:15:10:25 hal0 THE_RIG Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=1467634208_43d7826fbe5272d65f8447d74c2839b5 2016/6/4:15:10:26 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:10:50 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:10:50 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:10:50 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:10:57 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:10:58 hal0 THE_RIG Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=%s 2016/6/4:15:10:58 hal0 THE_RIG Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=1467634258_f85413a5d171edb321eb3b5800736376 2016/6/4:15:10:58 hal0 THE_RIG Download Play BACKBURNER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/BACKBURNER.tar.lzma2?authparam=%s 2016/6/4:15:11:02 hal0 THE_RIG Download Complete BACKBURNER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/BACKBURNER.tar.lzma2?authparam=1467634258_309d17f7506bbf9f67c9397f8925f38d 2016/6/4:15:11:02 hal0 THE_RIG Installing Autodesk® Backburner 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:11:10 hal0 THE_RIG Install Autodesk® Backburner 2017 Succeeded 2016/6/4:15:11:10 hal0 THE_RIG Download Play MENTALRAY http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MENTALRAY.tar.lzma2?authparam=%s 2016/6/4:15:11:18 hal0 THE_RIG Download Complete MENTALRAY http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MENTALRAY.tar.lzma2?authparam=1467634270_99e5a946cab6e86dfc9c2d7b4b04edee 2016/6/4:15:11:18 hal0 THE_RIG Installing NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:11:19 hal0 THE_RIG Install NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017 Succeeded 2016/6/4:15:11:19 hal0 THE_RIG Download Play ADSKAPP http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/ADSKAPP_x86.tar.lzma2?authparam=%s 2016/6/4:15:11:33 hal0 THE_RIG Download Complete ADSKAPP http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/ADSKAPP_x86.tar.lzma2?authparam=1467634279_ed47f1375d32588202eab6b9c6ff6445 2016/6/4:15:11:33 hal0 THE_RIG Installing Autodesk Desktop App: "C:\Autodesk\WI\Autodesk 3ds Max 2017\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe" 2016/6/4:15:11:33 hal0 THE_RIG Install Autodesk Desktop App Succeeded 2016/6/4:15:11:33 hal0 THE_RIG Download Play SUCCESSMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SUCCESSMARKER_x64.tar.lzma2?authparam=%s 2016/6/4:15:11:33 hal0 THE_RIG Download Complete SUCCESSMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SUCCESSMARKER_x64.tar.lzma2?authparam=1467634293_f00f2cc0eda34029b9feebafb2fbee78 2016/6/4:15:11:34 hal0 THE_RIG PageOpen InstallCompleteDialog 2016/6/4:15:11:51 hal0 THE_RIG === Setup ended === 2016/6/4:15:32:20 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:32:20 hal0 THE_RIG Path_Length: 157 2016/6/4:15:32:20 hal0 THE_RIG Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/6/4:15:32:20 hal0 THE_RIG Launch 2016/6/4:15:32:20 hal0 THE_RIG CommandLine 2016/6/4:15:32:20 hal0 THE_RIG Path_Length: 157 2016/6/4:15:32:20 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp 2016/6/4:15:32:23 hal0 THE_RIG === Setup ended === 2016/6/4:15:32:21 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:32:21 hal0 THE_RIG Path_Length: 157 2016/6/4:15:32:21 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp 2016/6/4:15:32:21 hal0 THE_RIG Launch 2016/6/4:15:32:24 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:32:37 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:32:46 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:32:46 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:32:54 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:32:54 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/6/4:15:32:58 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/6/4:15:32:58 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/6/4:15:33:01 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/6/4:15:33:01 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log 2016/6/4:15:33:04 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/6/4:15:33:04 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log 2016/6/4:15:33:07 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/6/4:15:33:07 hal0 THE_RIG Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:33:14 hal0 THE_RIG Install Autodesk® Material Library 2017 Succeeded 2016/6/4:15:33:14 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:33:17 hal0 THE_RIG Install Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:33:17 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:33:24 hal0 THE_RIG Install Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:33:24 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:33:26 hal0 THE_RIG Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:33:26 hal0 THE_RIG Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:33:35 hal0 THE_RIG Install Autodesk Licensing Manager Succeeded 2016/6/4:15:33:35 hal0 THE_RIG Installing Autodesk® 3ds Max® 2017: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:34:46 hal0 THE_RIG Install Autodesk® 3ds Max® 2017 Failed Installation aborted, Result=1603 2016/6/4:15:34:51 hal0 THE_RIG Rollback Autodesk Licensing Manager Succeeded 2016/6/4:15:34:52 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:34:55 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:34:58 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:35:03 hal0 THE_RIG Rollback Autodesk® Material Library 2017 Succeeded 2016/6/4:15:35:03 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/6/4:15:35:03 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/6/4:15:35:03 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/6/4:15:35:03 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619 2016/6/4:15:35:03 hal0 THE_RIG PageOpen InstallCompleteDialog 2016/6/4:15:35:05 hal0 THE_RIG === Setup ended === 2016/6/4:15:40:09 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:40:09 hal0 THE_RIG Path_Length: 157 2016/6/4:15:40:09 hal0 THE_RIG Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/6/4:15:40:09 hal0 THE_RIG Launch 2016/6/4:15:40:09 hal0 THE_RIG CommandLine 2016/6/4:15:40:09 hal0 THE_RIG Path_Length: 157 2016/6/4:15:40:09 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AID295.tmp 2016/6/4:15:40:12 hal0 THE_RIG === Setup ended === 2016/6/4:15:40:10 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:40:10 hal0 THE_RIG Path_Length: 157 2016/6/4:15:40:10 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AID295.tmp 2016/6/4:15:40:10 hal0 THE_RIG Launch 2016/6/4:15:40:12 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:40:16 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:40:22 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:40:22 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:40:24 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:40:24 hal0 THE_RIG Installing Autodesk® Backburner 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:40:27 hal0 THE_RIG Install Autodesk® Backburner 2017 Succeeded 2016/6/4:15:40:27 hal0 THE_RIG Installing Autodesk® Inventor Server Engine For 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:40:30 hal0 THE_RIG Install Autodesk® Inventor Server Engine For 3ds Max 2017 Succeeded 2016/6/4:15:40:30 hal0 THE_RIG Installing Autodesk® Revit® 2017 Interoperability for Autodesk® 3ds Max 2017: C_APP_NAME=3dsMax C_APP_VER=2017 C_RES=ENU RX_CF="Revit Interoperability 2017" ADDLOCAL=RevitEngine,RPC,MACRO,OGS INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:40:46 hal0 THE_RIG Install Autodesk® Revit® 2017 Interoperability for Autodesk® 3ds Max 2017 Succeeded 2016/6/4:15:40:46 hal0 THE_RIG Installing Autodesk® Civil View 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:41:05 hal0 THE_RIG Install Autodesk® Civil View 2017 Succeeded 2016/6/4:15:41:05 hal0 THE_RIG Installing NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:41:06 hal0 THE_RIG Install NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017 Succeeded 2016/6/4:15:41:06 hal0 THE_RIG Installing Autodesk Desktop App: "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe" 2016/6/4:15:41:31 hal0 THE_RIG Install Autodesk Desktop App Succeeded 2016/6/4:15:41:31 hal0 THE_RIG PageOpen InstallCompleteDialog 2016/6/4:15:41:45 hal0 THE_RIG === Setup ended === 2016/6/4:15:43:44 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:43:44 hal0 THE_RIG Path_Length: 157 2016/6/4:15:43:44 hal0 THE_RIG Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/6/4:15:43:44 hal0 THE_RIG Launch 2016/6/4:15:43:44 hal0 THE_RIG CommandLine 2016/6/4:15:43:44 hal0 THE_RIG Path_Length: 157 2016/6/4:15:43:44 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp 2016/6/4:15:43:48 hal0 THE_RIG === Setup ended === 2016/6/4:15:43:45 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:43:45 hal0 THE_RIG Path_Length: 157 2016/6/4:15:43:45 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp 2016/6/4:15:43:45 hal0 THE_RIG Launch 2016/6/4:15:43:48 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:43:52 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:43:54 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:43:54 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:43:59 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:43:59 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/6/4:15:44:03 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/6/4:15:44:03 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/6/4:15:44:06 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/6/4:15:44:06 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log 2016/6/4:15:44:10 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/6/4:15:44:10 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log 2016/6/4:15:44:13 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/6/4:15:44:13 hal0 THE_RIG Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:44:20 hal0 THE_RIG Install Autodesk® Material Library 2017 Succeeded 2016/6/4:15:44:20 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:44:23 hal0 THE_RIG Install Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:44:23 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:44:31 hal0 THE_RIG Install Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:44:31 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:44:32 hal0 THE_RIG Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:44:33 hal0 THE_RIG Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:44:43 hal0 THE_RIG Install Autodesk Licensing Manager Succeeded 2016/6/4:15:44:43 hal0 THE_RIG Installing Autodesk® 3ds Max® 2017: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:46:20 hal0 THE_RIG Install Autodesk® 3ds Max® 2017 Failed Installation aborted, Result=1603 2016/6/4:15:46:30 hal0 THE_RIG Rollback Autodesk Licensing Manager Succeeded 2016/6/4:15:46:31 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:46:34 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:46:37 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:46:42 hal0 THE_RIG Rollback Autodesk® Material Library 2017 Succeeded 2016/6/4:15:46:42 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/6/4:15:46:42 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/6/4:15:46:42 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/6/4:15:46:42 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619 2016/6/4:15:46:42 hal0 THE_RIG PageOpen InstallCompleteDialog 2016/6/4:15:46:45 hal0 THE_RIG === Setup ended === 2016/6/4:15:52:00 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:52:00 hal0 THE_RIG Path_Length: 157 2016/6/4:15:52:00 hal0 THE_RIG Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit 2016/6/4:15:52:00 hal0 THE_RIG Launch 2016/6/4:15:52:00 hal0 THE_RIG CommandLine 2016/6/4:15:52:00 hal0 THE_RIG Path_Length: 157 2016/6/4:15:52:00 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp 2016/6/4:15:52:02 hal0 THE_RIG === Setup ended === 2016/6/4:15:52:01 hal0 THE_RIG === Setup started on THE_RIG by hal0 === 2016/6/4:15:52:01 hal0 THE_RIG Path_Length: 157 2016/6/4:15:52:01 hal0 THE_RIG Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp 2016/6/4:15:52:01 hal0 THE_RIG Launch 2016/6/4:15:52:02 hal0 THE_RIG PageOpen LaunchDialog 2016/6/4:15:53:06 hal0 THE_RIG PageOpen LicenseDialog 2016/6/4:15:53:11 hal0 THE_RIG PageOpen ProductInfoDialog 2016/6/4:15:53:11 hal0 THE_RIG PageOpen ProductSelectionDialog2 2016/6/4:15:53:18 hal0 THE_RIG PageOpen FullProgressDialog 2016/6/4:15:53:18 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart 2016/6/4:15:53:22 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2016/6/4:15:53:22 hal0 THE_RIG Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart 2016/6/4:15:53:26 hal0 THE_RIG Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2016/6/4:15:53:26 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log 2016/6/4:15:53:30 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded 2016/6/4:15:53:30 hal0 THE_RIG Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log 2016/6/4:15:53:34 hal0 THE_RIG Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded 2016/6/4:15:53:34 hal0 THE_RIG Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:53:41 hal0 THE_RIG Install Autodesk® Material Library 2017 Succeeded 2016/6/4:15:53:41 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:53:45 hal0 THE_RIG Install Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:53:45 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:53:53 hal0 THE_RIG Install Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:53:53 hal0 THE_RIG Installing Autodesk® Material Library 2017 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:53:55 hal0 THE_RIG Install Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:53:55 hal0 THE_RIG Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:54:04 hal0 THE_RIG Install Autodesk Licensing Manager Succeeded 2016/6/4:15:54:05 hal0 THE_RIG Installing Autodesk® 3ds Max® 2017: TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/6/4:15:57:24 hal0 THE_RIG Install Autodesk® 3ds Max® 2017 Failed Installation aborted, Result=1603 2016/6/4:15:57:35 hal0 THE_RIG Rollback Autodesk Licensing Manager Succeeded 2016/6/4:15:57:36 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Advanced Material Image Library Succeeded 2016/6/4:15:57:39 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Medium Resolution Library Succeeded 2016/6/4:15:57:41 hal0 THE_RIG Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded 2016/6/4:15:57:46 hal0 THE_RIG Rollback Autodesk® Material Library 2017 Succeeded 2016/6/4:15:57:46 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619 2016/6/4:15:57:46 hal0 THE_RIG Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619 2016/6/4:15:57:46 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619 2016/6/4:15:57:46 hal0 THE_RIG Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
The log file cites Visual C++ 2013 and 2012 as failing to install, but they are allready installed and working properly.
Please help.
