Installation & Licensing
3ds Max 2017 Broken Installer/Website/Everything
9 REPLIES 9
Message 1 of 10
Space928
2820 Views, 9 Replies
I super excited when I logged back on to the Autodesk website to download 3ds Max for my new computer, when I saw that 3ds Max 2017 had been released. I had expected to spent mabye quater of an hour installing it, yet hear I am 3 days later with no success.
After looking through the logs and finding almost meaningless errors and trying every troubleshooting step I could think of including: reebooting, installing as many components as possible separatly, searching through the downloaded temp files and running and running a 3ds Max msi file which ended up kinda working as in it installed but didn't work and it was impossible to unistall (which resulted in be having to do a system restore).
After a lot more experimentation, I feel like I can safely conclude that 3ds Max 2017 is not ready for release. I mean two of the links on the installer go to 404 pages and the free trial download button on the website doesn't do anything. This is some really half baked stuff going on here and I was wondering if this was normal and if I could fix this.
9 REPLIES 9
Message 2 of 10
Otto
in reply to: Space928
Hello Space928 and welcome to the Autodesk community!
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 10
Space928
in reply to: Otto
The problem I'm having is not in uninstalling the product but in installing it. Also the virtual agent doesn't have the downloads for 3ds Max 2017.
Message 4 of 10
jeffrey.sin
Hi @Space928,
Welcome to the Community.
What exact error are you getting during download or installation? Can you try using the links below to download the installer instead? Ensure that both files are saved onto the same folder.
Autodesk 3ds Max 2017:
Part 1
Part 2
Let us know how it goes. Thanks.
Jeffrey Sin
Autodesk Customer Support
Message 5 of 10
TravisNave
If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
Autodesk Forums:
Message 6 of 10
Space928
in reply to: jeffrey.sin
Thanks for the direct download links, they fixed all my problems and I'm now enjoying using 3ds Max 2017. By the way, the install now never works for me I'll send an installation log for future reference to help with bug fixing.
Message 7 of 10
Space928
Here's an installation log to help Autodesk fix the bugs in the installer:
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	=== Setup started on THOMASDESKTOP-P by Thoma ===
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	Path_Length: 157
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	Launch
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	CommandLine	/PK 128I1 /SN 900-57968641 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?dummy=0"
2016/5/14:20:59:17	Thoma	THOMASDESKTOP-P	Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI50DD.tmp
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	=== Setup ended ===
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	=== Setup started on THOMASDESKTOP-P by Thoma ===
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	Path_Length: 157
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI50DD.tmp
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	Launch
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	Download	Skipped	SETUPMARKER	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	Download	Skipped	SETUP_CONFIG	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2
2016/5/14:20:59:18	Thoma	THOMASDESKTOP-P	PageOpen	LaunchDialog
2016/5/14:21:01:50	Thoma	THOMASDESKTOP-P	PageOpen	LicenseDialog
2016/5/14:21:01:50	Thoma	THOMASDESKTOP-P	PageOpen	ProductSelectionDialog2
2016/5/14:21:02:07	Thoma	THOMASDESKTOP-P	PageOpen	LicenseDialog
2016/5/14:21:02:07	Thoma	THOMASDESKTOP-P	PageOpen	LaunchDialog
2016/5/14:21:02:46	Thoma	THOMASDESKTOP-P	=== Setup ended ===
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	=== Setup started on THOMASDESKTOP-P by Thoma ===
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	Path_Length: 157
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	Launch
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	CommandLine	/PK 128I1 /SN 900-57968641 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?dummy=0"
2016/5/14:21:08:05	Thoma	THOMASDESKTOP-P	Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	=== Setup ended ===
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	=== Setup started on THOMASDESKTOP-P by Thoma ===
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	Path_Length: 157
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	Current Directory C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	Launch
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	Download	Skipped	SETUPMARKER	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	Download	Skipped	SETUP_CONFIG	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2
2016/5/14:21:08:06	Thoma	THOMASDESKTOP-P	PageOpen	LaunchDialog
2016/5/14:21:08:10	Thoma	THOMASDESKTOP-P	PageOpen	LicenseDialog
2016/5/14:21:08:10	Thoma	THOMASDESKTOP-P	PageOpen	ProductInfoDialog
2016/5/14:21:08:10	Thoma	THOMASDESKTOP-P	PageOpen	ProductSelectionDialog2
2016/5/14:21:08:37	Thoma	THOMASDESKTOP-P	PageOpen	FullProgressDialog
2016/5/14:21:08:37	Thoma	THOMASDESKTOP-P	Download	Play	STARTMARKER	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2
2016/5/14:21:08:37	Thoma	THOMASDESKTOP-P	Download	Complete	STARTMARKER	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2
2016/5/14:21:08:37	Thoma	THOMASDESKTOP-P	Download	Skipped	VCREDIST2012X86	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X86.tar.lzma2
2016/5/14:21:08:37	Thoma	THOMASDESKTOP-P	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Download	Skipped	VCREDIST2012X64	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X64.tar.lzma2
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Download	Skipped	VCREDIST2013X86	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X86.tar.lzma2
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Thoma\AppData\Local\Temp\vcredist_x86_2013.log
2016/5/14:21:08:38	Thoma	THOMASDESKTOP-P	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2016/5/14:21:08:39	Thoma	THOMASDESKTOP-P	Download	Skipped	VCREDIST2013X64	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X64.tar.lzma2
2016/5/14:21:08:39	Thoma	THOMASDESKTOP-P	Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Thoma\AppData\Local\Temp\vcredist_x64_2013.log
2016/5/14:21:08:39	Thoma	THOMASDESKTOP-P	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2016/5/14:21:08:39	Thoma	THOMASDESKTOP-P	Download	Skipped	CMAIL	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMAIL.tar.lzma2
2016/5/14:21:08:39	Thoma	THOMASDESKTOP-P	Installing Autodesk® Material Library 2017 - Advanced Material Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/5/14:21:08:41	Thoma	THOMASDESKTOP-P	Install	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/5/14:21:08:42	Thoma	THOMASDESKTOP-P	Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\Thoma\AppData\Local\Temp\_AI5F2E.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/5/14:21:08:49	Thoma	THOMASDESKTOP-P	Install	Autodesk Licensing Manager	Succeeded
2016/5/14:21:08:49	Thoma	THOMASDESKTOP-P	Download	Play	MAX	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2
2016/5/14:21:12:57	Thoma	THOMASDESKTOP-P	Download	Aborted	MAX	http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2
2016/5/14:21:12:57	Thoma	THOMASDESKTOP-P	Install	Autodesk® 3ds Max® 2017	Failed	Download Failed, Installation aborted, Result=1603
2016/5/14:21:13:08	Thoma	THOMASDESKTOP-P	Rollback	Autodesk Licensing Manager	Succeeded
2016/5/14:21:13:09	Thoma	THOMASDESKTOP-P	Rollback	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/5/14:21:13:09	Thoma	THOMASDESKTOP-P	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
2016/5/14:21:13:09	Thoma	THOMASDESKTOP-P	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
2016/5/14:21:13:09	Thoma	THOMASDESKTOP-P	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Failure is ignored, Result=1619
2016/5/14:21:13:09	Thoma	THOMASDESKTOP-P	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Failure is ignored, Result=1619
Tags (1)
Message 8 of 10
mtarggart
Jeffrey,
When I download the files, I get file names of "Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_001_002.sfx.1432150019" and "Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_002_002.sfx.1432150019", but they will not extract. I tried double-clicking and using 7-zip. Niether method works.
What else can be done?
Mike
Message 9 of 10
mtarggart
in reply to: mtarggart
Never mind. I figured out that I needed to change the number extension at the end to an .exe. Too bad I didn't think about this before posting the question. Maybe it will help someone else.
Message 10 of 10
I'm having the exact same issue. Instalation halts at part 5 of 15 (3d studio max 2017) at about 80% quoting the following error: "There is a problem with this Windows Installar Package. A program run as part of setup did not finish as expected."
This occurs regardless of using the web installer or the two redistributable packages downloaded from this thread. Really frustrating. Here is the log:
2016/6/4:15:04:58	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:04:58	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:04:58	hal0	THE_RIG	Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2016/6/4:15:04:58	hal0	THE_RIG	Launch
2016/6/4:15:04:58	hal0	THE_RIG	CommandLine	/URL "http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?authparam=b91ba1b191a933c9c10b81c98913132b812b1b811b991b3389b98913a1c933b9&SESSION_ID=a1b3A000009BGbkQAG" /skipPI /Trial /akamai
2016/6/4:15:04:58	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp
2016/6/4:15:04:59	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:04:58	hal0	THE_RIG	Download	Skipped	SETUPMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=1467630321_9bcc00207dedfd81b76a103387415bf0
2016/6/4:15:04:59	hal0	THE_RIG	Download	Skipped	SETUP_CONFIG	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=1467630322_64b41703c6815776d05843ae03ea8754
2016/6/4:15:04:59	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:05:03	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:05:10	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:05:10	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:05:29	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:05:29	hal0	THE_RIG	Download	Skipped	STARTMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=1467630631_3195fa5ba4fdb6bf68f4c204aa62b526
2016/6/4:15:05:30	hal0	THE_RIG	Download	Skipped	VCREDIST2012X86	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X86.tar.lzma2?authparam=1467630631_5bd964a8db3538c51e2b5a9e005f59d5
2016/6/4:15:05:30	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/6/4:15:05:33	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2016/6/4:15:05:34	hal0	THE_RIG	Download	Skipped	VCREDIST2012X64	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2012X64.tar.lzma2?authparam=1467630636_c0bcd7e76b4a98d279892e7c1c24fe13
2016/6/4:15:05:34	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/6/4:15:05:37	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2016/6/4:15:05:37	hal0	THE_RIG	Download	Skipped	VCREDIST2013X86	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X86.tar.lzma2?authparam=1467630641_f3d71d18f569250bef9d7501c47b77cf
2016/6/4:15:05:37	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log
2016/6/4:15:05:40	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2016/6/4:15:05:40	hal0	THE_RIG	Download	Skipped	VCREDIST2013X64	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDIST2013X64.tar.lzma2?authparam=1467630646_94e19baa96305447c80cdf621d239ba6
2016/6/4:15:05:40	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log
2016/6/4:15:05:45	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2016/6/4:15:05:45	hal0	THE_RIG	Download	Skipped	CM	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar.lzma2?authparam=1467630651_c25f1b352545476c9b32116fb2885ebf
2016/6/4:15:05:45	hal0	THE_RIG	Installing Autodesk® Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:05:51	hal0	THE_RIG	Install	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:05:51	hal0	THE_RIG	Download	Skipped	CMILB	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB.tar.lzma2?authparam=1467630701_4be5f0df90bdebf3c685f2caf61e90a0
2016/6/4:15:05:51	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:05:55	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:05:55	hal0	THE_RIG	Download	Skipped	CMILM	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM.tar.lzma2?authparam=1467630717_ed8a0ca237bb025d59b21d791176067f
2016/6/4:15:05:55	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:06:02	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:06:02	hal0	THE_RIG	Download	Skipped	CMAIL	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMAIL.tar.lzma2?authparam=1467630835_689f6527f4a3249ba8d1e2cde51b0bd4
2016/6/4:15:06:02	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Advanced Material Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:06:04	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:06:04	hal0	THE_RIG	Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:06:13	hal0	THE_RIG	Install	Autodesk Licensing Manager	Succeeded
2016/6/4:15:06:13	hal0	THE_RIG	Download	Skipped	MAX	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MAX.tar.lzma2?authparam=1467630868_837e3f2a11906bc4ba34033b0cdb0ea4
2016/6/4:15:06:14	hal0	THE_RIG	Installing Autodesk® 3ds Max® 2017:  TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI9A0C.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" INSTALLDIR="D:\3DSMax2017\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:09:12	hal0	THE_RIG	Install	Autodesk® 3ds Max® 2017	Failed	Installation aborted, Result=1603
2016/6/4:15:09:23	hal0	THE_RIG	Rollback	Autodesk Licensing Manager	Succeeded
2016/6/4:15:09:23	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:09:26	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:09:29	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:09:34	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:09:34	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
2016/6/4:15:09:34	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
2016/6/4:15:09:34	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Failure is ignored, Result=1619
2016/6/4:15:09:34	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Failure is ignored, Result=1619
2016/6/4:15:09:34	hal0	THE_RIG	PageOpen	InstallCompleteDialog
2016/6/4:15:09:36	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:10:07	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:10:07	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:10:07	hal0	THE_RIG	Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2016/6/4:15:10:07	hal0	THE_RIG	Launch
2016/6/4:15:10:07	hal0	THE_RIG	CommandLine	/akamai /sid a1b3A000009BGbkQAG /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US_Setup.exe?authparam=b91ba1b191a933c9c10b81c98913132b812b1b811b991b3389b98913a1c933b9&SESSION_ID=a1b3A000009BGbkQAG"
2016/6/4:15:10:07	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AI51FF.tmp
2016/6/4:15:10:26	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:10:08	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:10:08	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:10:08	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AI51FF.tmp
2016/6/4:15:10:08	hal0	THE_RIG	Launch
2016/6/4:15:10:08	hal0	THE_RIG	Download	Play	SETUPMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=%s
2016/6/4:15:10:08	hal0	THE_RIG	Download	Complete	SETUPMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPMARKER_x64.tar.lzma2?authparam=1467634208_d63710bd98e2a16f267f12fdd826a6b0
2016/6/4:15:10:08	hal0	THE_RIG	Download	Play	SETUP_CONFIG	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=%s
2016/6/4:15:10:25	hal0	THE_RIG	Download	Complete	SETUP_CONFIG	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_x64.tar.lzma2?authparam=1467634208_43d7826fbe5272d65f8447d74c2839b5
2016/6/4:15:10:26	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:10:50	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:10:50	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:10:50	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:10:57	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:10:58	hal0	THE_RIG	Download	Play	STARTMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=%s
2016/6/4:15:10:58	hal0	THE_RIG	Download	Complete	STARTMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTMARKER_x64.tar.lzma2?authparam=1467634258_f85413a5d171edb321eb3b5800736376
2016/6/4:15:10:58	hal0	THE_RIG	Download	Play	BACKBURNER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/BACKBURNER.tar.lzma2?authparam=%s
2016/6/4:15:11:02	hal0	THE_RIG	Download	Complete	BACKBURNER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/BACKBURNER.tar.lzma2?authparam=1467634258_309d17f7506bbf9f67c9397f8925f38d
2016/6/4:15:11:02	hal0	THE_RIG	Installing Autodesk® Backburner 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:11:10	hal0	THE_RIG	Install	Autodesk® Backburner 2017	Succeeded
2016/6/4:15:11:10	hal0	THE_RIG	Download	Play	MENTALRAY	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MENTALRAY.tar.lzma2?authparam=%s
2016/6/4:15:11:18	hal0	THE_RIG	Download	Complete	MENTALRAY	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/MENTALRAY.tar.lzma2?authparam=1467634270_99e5a946cab6e86dfc9c2d7b4b04edee
2016/6/4:15:11:18	hal0	THE_RIG	Installing NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:11:19	hal0	THE_RIG	Install	NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017	Succeeded
2016/6/4:15:11:19	hal0	THE_RIG	Download	Play	ADSKAPP	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/ADSKAPP_x86.tar.lzma2?authparam=%s
2016/6/4:15:11:33	hal0	THE_RIG	Download	Complete	ADSKAPP	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/ADSKAPP_x86.tar.lzma2?authparam=1467634279_ed47f1375d32588202eab6b9c6ff6445
2016/6/4:15:11:33	hal0	THE_RIG	Installing Autodesk Desktop App: "C:\Autodesk\WI\Autodesk 3ds Max 2017\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe"
2016/6/4:15:11:33	hal0	THE_RIG	Install	Autodesk Desktop App	Succeeded
2016/6/4:15:11:33	hal0	THE_RIG	Download	Play	SUCCESSMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SUCCESSMARKER_x64.tar.lzma2?authparam=%s
2016/6/4:15:11:33	hal0	THE_RIG	Download	Complete	SUCCESSMARKER	http://efulfillment.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SUCCESSMARKER_x64.tar.lzma2?authparam=1467634293_f00f2cc0eda34029b9feebafb2fbee78
2016/6/4:15:11:34	hal0	THE_RIG	PageOpen	InstallCompleteDialog
2016/6/4:15:11:51	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:32:20	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:32:20	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:32:20	hal0	THE_RIG	Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit
2016/6/4:15:32:20	hal0	THE_RIG	Launch
2016/6/4:15:32:20	hal0	THE_RIG	CommandLine
2016/6/4:15:32:20	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp
2016/6/4:15:32:23	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:32:21	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:32:21	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:32:21	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp
2016/6/4:15:32:21	hal0	THE_RIG	Launch
2016/6/4:15:32:24	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:32:37	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:32:46	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:32:46	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:32:54	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:32:54	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/6/4:15:32:58	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2016/6/4:15:32:58	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/6/4:15:33:01	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2016/6/4:15:33:01	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log
2016/6/4:15:33:04	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2016/6/4:15:33:04	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log
2016/6/4:15:33:07	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2016/6/4:15:33:07	hal0	THE_RIG	Installing Autodesk® Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:33:14	hal0	THE_RIG	Install	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:33:14	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:33:17	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:33:17	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:33:24	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:33:24	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Advanced Material Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:33:26	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:33:26	hal0	THE_RIG	Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:33:35	hal0	THE_RIG	Install	Autodesk Licensing Manager	Succeeded
2016/6/4:15:33:35	hal0	THE_RIG	Installing Autodesk® 3ds Max® 2017:  TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAA5F.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:34:46	hal0	THE_RIG	Install	Autodesk® 3ds Max® 2017	Failed	Installation aborted, Result=1603
2016/6/4:15:34:51	hal0	THE_RIG	Rollback	Autodesk Licensing Manager	Succeeded
2016/6/4:15:34:52	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:34:55	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:34:58	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:35:03	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:35:03	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
2016/6/4:15:35:03	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
2016/6/4:15:35:03	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Failure is ignored, Result=1619
2016/6/4:15:35:03	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Failure is ignored, Result=1619
2016/6/4:15:35:03	hal0	THE_RIG	PageOpen	InstallCompleteDialog
2016/6/4:15:35:05	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:40:09	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:40:09	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:40:09	hal0	THE_RIG	Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit
2016/6/4:15:40:09	hal0	THE_RIG	Launch
2016/6/4:15:40:09	hal0	THE_RIG	CommandLine
2016/6/4:15:40:09	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AID295.tmp
2016/6/4:15:40:12	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:40:10	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:40:10	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:40:10	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AID295.tmp
2016/6/4:15:40:10	hal0	THE_RIG	Launch
2016/6/4:15:40:12	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:40:16	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:40:22	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:40:22	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:40:24	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:40:24	hal0	THE_RIG	Installing Autodesk® Backburner 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:40:27	hal0	THE_RIG	Install	Autodesk® Backburner 2017	Succeeded
2016/6/4:15:40:27	hal0	THE_RIG	Installing Autodesk® Inventor Server Engine For 3ds Max 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:40:30	hal0	THE_RIG	Install	Autodesk® Inventor Server Engine For 3ds Max 2017	Succeeded
2016/6/4:15:40:30	hal0	THE_RIG	Installing Autodesk® Revit® 2017 Interoperability for Autodesk® 3ds Max 2017:  C_APP_NAME=3dsMax C_APP_VER=2017 C_RES=ENU RX_CF="Revit Interoperability 2017" ADDLOCAL=RevitEngine,RPC,MACRO,OGS INSTALLDIR="C:\Program Files\Autodesk\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:40:46	hal0	THE_RIG	Install	Autodesk® Revit® 2017 Interoperability for Autodesk® 3ds Max 2017	Succeeded
2016/6/4:15:40:46	hal0	THE_RIG	Installing Autodesk® Civil View 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:41:05	hal0	THE_RIG	Install	Autodesk® Civil View 2017	Succeeded
2016/6/4:15:41:05	hal0	THE_RIG	Installing NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:41:06	hal0	THE_RIG	Install	NVIDIA mental ray and IRay rendering plugins for 3ds Max 2017	Succeeded
2016/6/4:15:41:06	hal0	THE_RIG	Installing Autodesk Desktop App: "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe"
2016/6/4:15:41:31	hal0	THE_RIG	Install	Autodesk Desktop App	Succeeded
2016/6/4:15:41:31	hal0	THE_RIG	PageOpen	InstallCompleteDialog
2016/6/4:15:41:45	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:43:44	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:43:44	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:43:44	hal0	THE_RIG	Current Directory E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit
2016/6/4:15:43:44	hal0	THE_RIG	Launch
2016/6/4:15:43:44	hal0	THE_RIG	CommandLine
2016/6/4:15:43:44	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp
2016/6/4:15:43:48	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:43:45	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:43:45	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:43:45	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp
2016/6/4:15:43:45	hal0	THE_RIG	Launch
2016/6/4:15:43:48	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:43:52	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:43:54	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:43:54	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:43:59	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:43:59	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/6/4:15:44:03	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2016/6/4:15:44:03	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/6/4:15:44:06	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2016/6/4:15:44:06	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x86): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log
2016/6/4:15:44:10	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2016/6/4:15:44:10	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x64): "E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log
2016/6/4:15:44:13	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2016/6/4:15:44:13	hal0	THE_RIG	Installing Autodesk® Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:44:20	hal0	THE_RIG	Install	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:44:20	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:44:23	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:44:23	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:44:31	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:44:31	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Advanced Material Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:44:32	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:44:33	hal0	THE_RIG	Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:44:43	hal0	THE_RIG	Install	Autodesk Licensing Manager	Succeeded
2016/6/4:15:44:43	hal0	THE_RIG	Installing Autodesk® 3ds Max® 2017:  TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AI1935.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\ISO\(1) Software\3ds Max 2017\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:46:20	hal0	THE_RIG	Install	Autodesk® 3ds Max® 2017	Failed	Installation aborted, Result=1603
2016/6/4:15:46:30	hal0	THE_RIG	Rollback	Autodesk Licensing Manager	Succeeded
2016/6/4:15:46:31	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:46:34	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:46:37	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:46:42	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:46:42	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
2016/6/4:15:46:42	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
2016/6/4:15:46:42	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Failure is ignored, Result=1619
2016/6/4:15:46:42	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Failure is ignored, Result=1619
2016/6/4:15:46:42	hal0	THE_RIG	PageOpen	InstallCompleteDialog
2016/6/4:15:46:45	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:52:00	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:52:00	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:52:00	hal0	THE_RIG	Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit
2016/6/4:15:52:00	hal0	THE_RIG	Launch
2016/6/4:15:52:00	hal0	THE_RIG	CommandLine
2016/6/4:15:52:00	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp
2016/6/4:15:52:02	hal0	THE_RIG	=== Setup ended ===
2016/6/4:15:52:01	hal0	THE_RIG	=== Setup started on THE_RIG by hal0 ===
2016/6/4:15:52:01	hal0	THE_RIG	Path_Length: 157
2016/6/4:15:52:01	hal0	THE_RIG	Current Directory C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp
2016/6/4:15:52:01	hal0	THE_RIG	Launch
2016/6/4:15:52:02	hal0	THE_RIG	PageOpen	LaunchDialog
2016/6/4:15:53:06	hal0	THE_RIG	PageOpen	LicenseDialog
2016/6/4:15:53:11	hal0	THE_RIG	PageOpen	ProductInfoDialog
2016/6/4:15:53:11	hal0	THE_RIG	PageOpen	ProductSelectionDialog2
2016/6/4:15:53:18	hal0	THE_RIG	PageOpen	FullProgressDialog
2016/6/4:15:53:18	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/6/4:15:53:22	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x86)	Succeeded
2016/6/4:15:53:22	hal0	THE_RIG	Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/6/4:15:53:26	hal0	THE_RIG	Install	Microsoft Visual C++ 2012 Redistributable (x64)	Succeeded
2016/6/4:15:53:26	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x86_2013.log
2016/6/4:15:53:30	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2016/6/4:15:53:30	hal0	THE_RIG	Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\hal0\AppData\Local\Temp\vcredist_x64_2013.log
2016/6/4:15:53:34	hal0	THE_RIG	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2016/6/4:15:53:34	hal0	THE_RIG	Installing Autodesk® Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:53:41	hal0	THE_RIG	Install	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:53:41	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:53:45	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:53:45	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:53:53	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:53:53	hal0	THE_RIG	Installing Autodesk® Material Library 2017 - Advanced Material Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:53:55	hal0	THE_RIG	Install	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:53:55	hal0	THE_RIG	Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp\x64\CLIC\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:54:04	hal0	THE_RIG	Install	Autodesk Licensing Manager	Succeeded
2016/6/4:15:54:05	hal0	THE_RIG	Installing Autodesk® 3ds Max® 2017:  TRANSFORMS="C:\Users\hal0\AppData\Local\Temp\_AIAB13.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2017\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/4:15:57:24	hal0	THE_RIG	Install	Autodesk® 3ds Max® 2017	Failed	Installation aborted, Result=1603
2016/6/4:15:57:35	hal0	THE_RIG	Rollback	Autodesk Licensing Manager	Succeeded
2016/6/4:15:57:36	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Advanced Material Image Library	Succeeded
2016/6/4:15:57:39	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Medium Resolution Library	Succeeded
2016/6/4:15:57:41	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017 - Base Image Library	Succeeded
2016/6/4:15:57:46	hal0	THE_RIG	Rollback	Autodesk® Material Library 2017	Succeeded
2016/6/4:15:57:46	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
2016/6/4:15:57:46	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
2016/6/4:15:57:46	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x64)	Failed	Failure is ignored, Result=1619
2016/6/4:15:57:46	hal0	THE_RIG	Rollback	Microsoft Visual C++ 2012 Redistributable (x86)	Failed	Failure is ignored, Result=1619
The log file cites Visual C++ 2013 and 2012 as failing to install, but they are allready installed and working properly.
Please help.
Administrator Productivity
