Installing 2022 on Windows 7
peterm
Message 1 of 40
peterm
Is there a way to install AutoCAD 2022 on a Windows 7 machine?
Replies (39)
Message 21 of 40
mdavis22569
Try forcing it like my AKN explains.
Might need to look at uninstalling and reinstalling the driver.  Once it's DirectX you'll have access to the HA again.
Mike Davis
Message 22 of 40
mdavis22569
@peterm
Did this get your the DirectX working
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/how-to-mak...
Mike Davis
Message 23 of 40
peterm
Hi Michael,
It did work, but then I had some other issues.
Anyway, I am currently setting up a new machine which is running Windows 10 and has a Quadro card, so hopefully everything will work fine.
Message 24 of 40
mdavis22569
I would review the following:
Mike Davis
Message 25 of 40
gideoncorbyTFSTT
Observer
Observer
0
Message 26 of 40
pendean
Community Legend
Community Legend
@gideoncorbyTFSTT Win7 is not a supported OS. Sorry, you are just out of luck today before your upgrade next month.
Message 27 of 40
gideoncorbyTFSTT
Observer
Observer
0
Message 28 of 40
TravisNave
I have it running on my Windows 7, so it can be done. Just gotta be
persistent. I don't really have time to explain it here right now but the
instructions are out there.
Autodesk Forums:
Message 29 of 40
gideoncorbyTFSTT
Observer
Observer
O
Message 30 of 40
marifgo
Hi. Please can you explain how to install Autocad2022 in Windows 7? Thank you.
Message 31 of 40
pendean
Community Legend
Community Legend
@marifgo Dumb question, forgive me, but why not just upgrade to Win10 or Win11 for free on your Win7 computer?
Message 32 of 40
marifgo
Because Win10 bugs the machine. I have 30 machines with Win7. If you can help thank you. Another user managed to install Autocad 2022 on Win7 but he didn't explain.
Message 33 of 40
mdavis22569
You're going to have issues @marifgo    C++/.NET limitations I'm betting too.    Go to 11 since you don't like 10.
Mike Davis
Message 34 of 40
pendean
Community Legend
Community Legend
I won't tell the other millions of corporate users who do not have this problem: perhaps a better IT team can resolve it all for you. I suggest, if egos will not be damaged, to hire a capable team from here https://servicesmarketplace.autodesk.com/
Finding a larger reseller outfit, if yours does not offer that service, is another option https://www.autodesk.com/partners/locate-a-reseller
Or as suggested by others, Win11 is your next option.
Hope your IT egos remain intact.
Message 35 of 40
mdavis22569
@pendean
Don't think the market place is fully going .. they are changing it some ( more hoops to jump through) .. then it's back April 1st.
Mike Davis
Message 36 of 40
pendean
Community Legend
Community Legend
@mdavis22569 Too bad. I revised my reply to add another option.
Message 37 of 40
mdavis22569
yeah .. help set it up only to be told I need to be a "partner" approved Authorized vendor etc etc ... Another day for that story .
Mike Davis
Message 38 of 40
marifgo
Initially I asked for help to install autocad2022 on windows 7 because I received an error after the installation preparation screen and I thought it was because of the system that was causing this error. To my surprise I upgraded win7 to win10 and I get the same error message!Error ACAD2022.jpg
Message 39 of 40
mdavis22569
You seem surprised
With all the C++/Net changes and requirements  .. You'd be lucky to keep it running long if you were to get it installed.
Mike Davis
Message 40 of 40
pendean
Community Legend
Community Legend
@ marifgo You need to find an share your installation log file content: stopping and staring at a pop-up like that means nothing to anyone and does not help you ever resolve a software install problem.
Try again: the log file is in your WindowsOS log0in TEMP folder accessed from Windows File Manager with this address:
%TEMP%
HTH
