FlexLM Service doesnt start
Message 2 of 37
We use Lmtools a lot of time, but from today we start reaching the problem with it.
In debug they stop on the detecting other license server manager (lmgrd).
I doesnt know waht to do. Please help me. Thank you,
Replies (36)
Message 21 of 37
TravisNave
Yes. Run your license thru this and then give me the results:
http://licenseparser.com/
Autodesk Forums:
Message 22 of 37
I clear serial numbers.
Message 23 of 37
TravisNave
Thanks. Looks good. Can you get me a screencap of your System Settings
tab in LMTOOLS? Or save out the HOSTID button?
Autodesk Forums:
Message 24 of 37
Please, it's in attached file
Message 25 of 37
TravisNave
Here is the 11.7 lmgrd.exe.  Try this with the 11.7 adskflex.exe from my other post.
Autodesk Forums:
Message 26 of 37
Message 27 of 37
Still same, sadanly.
Message 28 of 37
TravisNave
Make sure all the services are stopped before you try replacing the files.  You should also repoint your services to the new files and save it before restarting the service.
Autodesk Forums:
Message 29 of 37
Of course I does this. I think I need ask autodesk support by the hot line (((
Message 30 of 37
TravisNave
Also make sure you check the box on the first tab to ignore system
variables. Then start the service again.
Can you even do a Status Enquiry?
Autodesk Forums:
Message 31 of 37
TravisNave
https://global.gotomeeting.com/join/434765893
Let me check. I have a few minutes before I leave for the day. Join this
meeting.
Autodesk Forums:
Message 32 of 37
Yes it's checked, and I cant perform status enquiry because program is going to freeze
Message 33 of 37
Darin.Green
Hi @Anonymous was @TravisNave able to resolve the issue for you? If so, please accept his response as the solution.
If not, try updating the license manager to the Latest Version 11.12. Not sure why you're using 11.7...
If this information was helpful, please consider using the Accept Solution
Message 34 of 37
TravisNave
Darrin, I had him try 11.7 as a test in the small chance that 11.12 was not working for his R2 server.  I have seen this happen.
His server has an interesting situation where the service simply does not start.  I have a sneaking suspicion that there is a 3rd party security software on the server that is blocking access.  The adskflex.exe never fires off and the debug hangs on detecting other lmgrd.exe services.  Definitely an odd one because everything else checks out.  It has to be a conflict somewhere.
Autodesk Forums:
Message 35 of 37
Darin.Green
I've had that issue in the past as well... 🙂
You may have already tried this but here's what I've done in the past...
Update the license manager to the lastest version > Stopped then deleted the service via LMTOOLS. Next, I created a new service using a completely different name and repathed everything > Saved Settings then used the restart server option from the Start/Stop/Reread tab.
Another thought I have is to check the ADSKFLEX_LICENSE_FILE key within the registry location:
HKEY_CURRENT_USER\Software\FLEXlm License Manager
The value could have other servers specified blocking the ability to stop or run queries.
Message 36 of 37
TravisNave
Yep, tried all the usual ones. Very odd behavior.
Autodesk Forums:
Message 37 of 37
Hi, I'm late to the thread, let me know if I should start a new one but my issue is similar to the one in this thread. At one of my clients that I support, they just installed LMTools 11.14.1.3 on a 2nd server running 2012 R2. They also have an existing LMTools 11.12.0.0 build 136775 x64_n6 running on a 2008 R2 box. They configured some workstations to pull licenses from the new server while some are still getting licenses from the old server. They stated the reason for installing 2nd server is in case the old one fails. To migrate all workstations to the new license server is a time consuming process which I'll undertake once I can get the LMTools to run as a service on the newer server.
Client called us to report that the LMTools running on the new server closes unexpectedly. I found the application was not configured to run as a service. I configured to run as a service but the service will not start.
Recent entries from the debug log:
10:01:45 (adskflex) TIMESTAMP 4/19/2019
13:02:00 (adskflex) (@adskflex-SLOG@) ===============================================
13:02:00 (adskflex) (@adskflex-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
13:02:00 (adskflex) (@adskflex-SLOG@) Time: Fri Apr 19 2019 13:02:00 Eastern Daylight Time
13:02:00 (adskflex) (@adskflex-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 13:01:35 Eastern Daylight Time,#4,(4120K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 13:01:10 Eastern Daylight Time,#4,(4120K),(dmartinez,DELL51,808)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 13:00:35 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 13:00:10 Eastern Daylight Time,#4,(4112K),(dmartinez,DELL51,808)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:59:35 Eastern Daylight Time,#4,(4060K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:59:10 Eastern Daylight Time,#4,(4116K),(dmartinez,DELL51,808)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:58:35 Eastern Daylight Time,#4,(4116K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:58:10 Eastern Daylight Time,#4,(4116K),(dmartinez,DELL51,808)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:57:35 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 12:57:10 Eastern Daylight Time,#4,(4112K),(dmartinez,DELL51,808)
13:02:00 (adskflex) (@adskflex-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
13:02:00 (adskflex) (@adskflex-SLOG@) 00009313 ms at Thu Apr 18 2019 09:52:22 Eastern Daylight Time,#5,(3964K),(administrator,SSA-DC02,648)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000016 ms at Wed Apr 17 2019 15:28:53 Eastern Daylight Time,#3,(3336K),(administrator,SSA-DC02,716)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 09:03:34 Eastern Daylight Time,#3,(3544K),(administrator,SSA-DC02,716)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 14:39:44 Eastern Daylight Time,#4,(4020K),(dmartinez,DELL51,680)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 15:07:44 Eastern Daylight Time,#4,(4016K),(dmartinez,DELL51,680)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000015 ms at Fri Apr 19 2019 08:02:35 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000015 ms at Thu Apr 18 2019 10:13:30 Eastern Daylight Time,#4,(4020K),(grodriguez,Dell71,708)
13:02:00 (adskflex) (@adskflex-SLOG@) 00000015 ms at Tue Apr 16 2019 09:02:10 Eastern Daylight Time,#4,(3244K),(administrator,SSA-DC02,628)
13:02:00 (adskflex) (@adskflex-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
13:02:00 (adskflex) (@adskflex-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
13:02:00 (adskflex) (@adskflex-SLOG@) In-house operation time, when, #concurrent clients
13:02:00 (adskflex) (@adskflex-SLOG@) === Active Connections Info ===
13:02:00 (adskflex) (@adskflex-SLOG@) Peak active connections #6 attempted at Thu Apr 18 2019 09:35:44 Eastern Daylight Time
13:02:00 (adskflex) (@adskflex-SLOG@) === Memory Usage Info ===
13:02:00 (adskflex) (@adskflex-SLOG@) Peak private bytes 4192K attempted at Fri Apr 19 2019 08:23:35 Eastern Daylight Time
15:01:45 (lmgrd) TIMESTAMP 4/19/2019
16:06:46 (adskflex) TIMESTAMP 4/19/2019
17:02:01 (adskflex) (@adskflex-SLOG@) ===============================================
17:02:01 (adskflex) (@adskflex-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
17:02:01 (adskflex) (@adskflex-SLOG@) Time: Fri Apr 19 2019 17:02:01 Eastern Daylight Time
17:02:01 (adskflex) (@adskflex-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:01:36 Eastern Daylight Time,#4,(4116K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:01:10 Eastern Daylight Time,#4,(4116K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:00:36 Eastern Daylight Time,#4,(4060K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:00:10 Eastern Daylight Time,#4,(4060K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:59:36 Eastern Daylight Time,#4,(4120K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:59:10 Eastern Daylight Time,#4,(4120K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:58:36 Eastern Daylight Time,#4,(4060K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:58:10 Eastern Daylight Time,#4,(4112K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:57:36 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 16:57:10 Eastern Daylight Time,#4,(4112K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
17:02:01 (adskflex) (@adskflex-SLOG@) 00009313 ms at Thu Apr 18 2019 09:52:22 Eastern Daylight Time,#5,(3964K),(administrator,SSA-DC02,648)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Wed Apr 17 2019 15:28:53 Eastern Daylight Time,#3,(3336K),(administrator,SSA-DC02,716)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 09:03:34 Eastern Daylight Time,#3,(3544K),(administrator,SSA-DC02,716)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 14:39:44 Eastern Daylight Time,#4,(4020K),(dmartinez,DELL51,680)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 15:07:44 Eastern Daylight Time,#4,(4016K),(dmartinez,DELL51,680)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Fri Apr 19 2019 16:19:10 Eastern Daylight Time,#4,(4116K),(dmartinez,DELL51,808)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Fri Apr 19 2019 08:02:35 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Thu Apr 18 2019 10:13:30 Eastern Daylight Time,#4,(4020K),(grodriguez,Dell71,708)
17:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Tue Apr 16 2019 09:02:10 Eastern Daylight Time,#4,(3244K),(administrator,SSA-DC02,628)
17:02:01 (adskflex) (@adskflex-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
17:02:01 (adskflex) (@adskflex-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
17:02:01 (adskflex) (@adskflex-SLOG@) In-house operation time, when, #concurrent clients
17:02:01 (adskflex) (@adskflex-SLOG@) === Active Connections Info ===
17:02:01 (adskflex) (@adskflex-SLOG@) Peak active connections #6 attempted at Thu Apr 18 2019 09:35:44 Eastern Daylight Time
17:02:01 (adskflex) (@adskflex-SLOG@) === Memory Usage Info ===
17:02:01 (adskflex) (@adskflex-SLOG@) Peak private bytes 4192K attempted at Fri Apr 19 2019 08:23:35 Eastern Daylight Time
17:05:19 (adskflex) IN: "86718CIV3D_2017_0F" dmartinez@DELL51
17:05:19 (adskflex) IN: "64900CIV3D_F" dmartinez@DELL51
17:57:10 (adskflex) IN: "86718CIV3D_2017_0F" grodriguez@Dell71
17:57:10 (adskflex) IN: "64900CIV3D_F" grodriguez@Dell71
21:01:46 (lmgrd) TIMESTAMP 4/19/2019
21:02:01 (adskflex) (@adskflex-SLOG@) ===============================================
21:02:01 (adskflex) (@adskflex-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
21:02:01 (adskflex) (@adskflex-SLOG@) Time: Fri Apr 19 2019 21:02:01 Eastern Daylight Time
21:02:01 (adskflex) (@adskflex-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:57:10 Eastern Daylight Time,#3,(4120K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:56:36 Eastern Daylight Time,#3,(4060K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:55:36 Eastern Daylight Time,#3,(4116K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:54:36 Eastern Daylight Time,#3,(4060K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:53:36 Eastern Daylight Time,#3,(4112K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:52:36 Eastern Daylight Time,#3,(4060K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:51:36 Eastern Daylight Time,#3,(4120K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:50:36 Eastern Daylight Time,#3,(4060K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:49:36 Eastern Daylight Time,#3,(4116K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000000 ms at Fri Apr 19 2019 17:48:36 Eastern Daylight Time,#3,(4060K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
21:02:01 (adskflex) (@adskflex-SLOG@) 00009313 ms at Thu Apr 18 2019 09:52:22 Eastern Daylight Time,#5,(3964K),(administrator,SSA-DC02,648)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Wed Apr 17 2019 15:28:53 Eastern Daylight Time,#3,(3336K),(administrator,SSA-DC02,716)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 09:03:34 Eastern Daylight Time,#3,(3544K),(administrator,SSA-DC02,716)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 14:39:44 Eastern Daylight Time,#4,(4020K),(dmartinez,DELL51,680)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Thu Apr 18 2019 15:07:44 Eastern Daylight Time,#4,(4016K),(dmartinez,DELL51,680)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000016 ms at Fri Apr 19 2019 16:19:10 Eastern Daylight Time,#4,(4116K),(dmartinez,DELL51,808)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Fri Apr 19 2019 08:02:35 Eastern Daylight Time,#4,(4112K),(grodriguez,Dell71,752)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Thu Apr 18 2019 10:13:30 Eastern Daylight Time,#4,(4020K),(grodriguez,Dell71,708)
21:02:01 (adskflex) (@adskflex-SLOG@) 00000015 ms at Tue Apr 16 2019 09:02:10 Eastern Daylight Time,#4,(3244K),(administrator,SSA-DC02,628)
21:02:01 (adskflex) (@adskflex-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
21:02:01 (adskflex) (@adskflex-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
21:02:01 (adskflex) (@adskflex-SLOG@) In-house operation time, when, #concurrent clients
21:02:01 (adskflex) (@adskflex-SLOG@) === Active Connections Info ===
21:02:01 (adskflex) (@adskflex-SLOG@) Peak active connections #6 attempted at Thu Apr 18 2019 09:35:44 Eastern Daylight Time
21:02:01 (adskflex) (@adskflex-SLOG@) === Memory Usage Info ===
21:02:01 (adskflex) (@adskflex-SLOG@) Peak private bytes 4192K attempted at Fri Apr 19 2019 08:23:35 Eastern Daylight Time
22:11:47 (adskflex) TIMESTAMP 4/19/2019
