AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2013 hang issue
4 REPLIES 4
432 Views, 4 Replies
I am facing issue with AutoCAD while using. It stucks when open and showing "Not responding" and nothing were happened after it.
I have a stand-alone license of it.
Contact No: 9999189707
4 REPLIES 4
TravisNave
Turn off the welcome screen by unchecking the box on it.  Then turn off digital signature icons by right-clicking the launch icon and choosing Enable/Disable Digital Signature Icons.  Uncheck that box.  Reboot.  Also make sure you don't have disconnected mapped network drives or offline network printers.  If so, correct them.
What OS are you installed on?  Has this worked better in the recent past?  Also, do not open AutoCAD by double-clicking a drawing.  Open the program by the launch icon.  And do not work on files over the network.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Yes it was working in past days.
I am using Win 7 Enterprise SP1 64-bit
TravisNave
If it was working before, then I would suggest doing a System Restore back
to when you knew it was working better. Then see if that fixes it.
Autodesk Forums:
things you can try:
- start Map with a new profile
  * copy your Map icon on desktop
  * open icon properties, under Shortcut in "Target" add at the end /p test or if /p is already set then change whatever is written after to test (new profile name)
  * start Map - will will show message that profile test was not found - just click ok and see if Map starts up properly
- login with different Windows user (if possible) and let that user start Map - if Map starts then something is wrong with your profile settings - set Map settings back to default (Programs > Autodesk > Map > reset)
Good luck, Rob
